That's a really good point. I was actually interested in power delivery for SD cards as well. Unfortunately didn't have enough time yet.... Different SD cards will have a different sensitivity to voltage, and different current usage, but they should be isolated from the 5V supply since they operate at 3.3V or 1.8V. ...
Basically what i did as well. The advantage of a short cable is also that one doesn't need that heavy gauge.My guess is that the solution to this problem is to use a power supply that is slightly on the high side of 5V (maybe 5.3V) and to use the shortest heaviest gauge USB cable you can find, (or do as I did, build your own power only cable with lamp cord) Alternatively, run the 12V to the camera location and use a 6" USB cable to the power supply.
Well, capacitors have also a resistance and inductance (ESL, ESR) which alternate its properties. And used electrolytic capacitors are not the best for "fast changes". (but it's good as a slow power buffer)You may be right with this, but honestly I really struggle to understand why those fancy supercapacitors fail to smooth the voltage, ...
The PCB design could be significantly different. (don't know, don't have one) Not to mention A129Pro works with faster interfaces which makes it more sensitive to ambient influence....also for those who have reverted to the A129 (non-pro) why do they not suffer the same ongoing problem. Certainly when it comes to driving mode, I realise that others have also speculated that power is a crash-inducing factor.
Are you sure about that? I don't see a point to not connect them directly. (but i haven't traced the connection though)The supercaps in a dashcam are not directly connected to the power input so they will not provide any power-filtering or smoothing.
the pro has higher power consumption than the regular A129, may be a factor in why the problem doesn't happen, if it is power supply related at leastThe PCB design could be significantly different. (don't know, don't have one) Not to mention A129Pro works with faster interfaces which makes it more sensitive to ambient influence.
I found that if you set A129 Pro to FHD (1080P), almost all problems go away as though as you switched to A129. The extra is, you get 60fps instead of 30fps. The cons is, you paid for 4K dashcam but only get to use it as a FHD dashcam.
Sent from my SM-N975F using Tapatalk
That's the latest official version.What's the latest official firmware version for this dashcam? I have 1.1
Just wanted to chime in and say after upgrading to 1.7T and turning off Parking Mode, I have had zero problems with this dashcam. No problems whatsoever.
Polish "branch" website has official v1.3 and many users got the cam with this version out of the box.That's the latest official version.
Yes, and newer camera have been shipping with V1.4. According to Viofo the differences are negligible, so they have left V1.1 as their latest official firmware. The Polish site is just a seller site, not direct relation to Viofo.Polish "branch" website has official v1.3 and many users got the cam with this version out of the box.
No problem at all to downgrade the firmware at any time. Just remember to reset to default after the FW change, as you should with any FW change. Also reformat the card in camera before use.Anyone try upgrade to new then downgrade back to original firmware? Any fail or malfunctioning after all?
I received a new one today from the lovely people at www.mycrocamuk.co.uk and it came with firmware version 1.3 build 20200103
This is odd considering that the Viofo site only mentions version 1.1
VIOFO A129 Pro Duo Dash Camera Firmware
Please click below for the A129 Pro support page. A129 Pro Support pagesupport.viofo.com
if there's a way to extract/save the firmware I'd be quite interested.
Keep your current firmware until you have properly tested it and made sure everything is working correctly.I received a new one today from the lovely people at www.mycrocamuk.co.uk and it came with firmware version 1.3 build 20200103
I downloaded the firmware anyway and ran "strings" on it and it appears to be running linux!
