How are you setting the time - manually or with GPS? Have you checked that your GMT +/- setting is correct?
Oops, post this to the wrong person. Disregard.
Okay, I might have found a solution. First of all, in the beginning, when I installed v2.0, I used the iPhone App to set my settings, initially sync with my iPhone. However, notice lots of odds things happening. The VIOFO app messes up the settings badly. I stop using it. Did a reset and manually entered my preferred settings. Usually in the morning 8:00 AM, which is what I entered. My GMT is always 6+. However next day, it off by 12 hours.
As mention in previous post, I waited in afternoon, using the 24 hour format, set it to 16 hours, the minutes and seconds are okay. Verified the date was correct. Exit out, and notice the time was correct, but the date was off by 1 day. So, I went into the date setting and changed the date to the correct day.
Next morning, I check and my dates changes held. Seems to overcome the problem, as long as I don't set the time in the morning. Must be an error in the coding?
As long as it stays, all okay here.
Now the next thing, I need to verify is parking mode. I notice when I enter the park vehicle, I get my beeps (which is what I want, telling me it recording and active). However, it doesn't happen all the time (made changes in testing). Not sure yet, but if the set the park timer to OFF, no beeps ( I want recording with no delay, which I assume it meant), if I set it to 90 secs, I get my beeps, indicating it recording. Is this normal and intended? If so, that can throw people off with parking failure.
