I'm using a 256GB card in the camera, this should record more than 10 hours of video.
I have the camera set to 5 minute files so that they don't exceed the 4GB limit of FAT32.
There are no missing files.
The file that should have contained the event was under size and contained only 45 seconds.
The next file started 5 minutes after the short file started.
The 1 hour limit applies only to TeslaCAM (something I REALLY wish that they would fix).
edit: I decided to take a closer look at the files. It looks like every file was being truncated to 45 seconds that day. The time between files was random, sometimes only 5 seconds other, as in this case, several minutes.
In the file listing below, the middle file is the one that should have contained the incident.
Code:
-r--r--r-- 1 DAP DAP 49114547 Nov 27 06:06 20201127_140558_00504PF.MP4
-r--r--r-- 1 DAP DAP 76266079 Nov 27 06:07 20201127_140704_00505PF.MP4
-r--r--r-- 1 DAP DAP 64221779 Nov 27 06:11 20201127_141045_00506PF.MP4
Earlier that day, there were some 1.9GB 5 minute files. but during the drive where the incident was, they were all about 64 MB.
I have an identical rear camera with exactly the same type of memory card. The rear camera was recording perfectly at the time, but because it was pointed to the rear, missed the accident entirely.
Both cameras are running version 2.1 with build 20200803
edit2: I just drove for 300 miles. The front camera worked properly for 125 miles until I stopped to supercharge. After that, it only recorded 45 second files. I had formatted the card in the camera before starting, so the memory card is not full. The back camera worked perfectly. It recorded 59 second files while parked at the supercharger. and always 5 minute files while moving.
I'm beginning to suspect that the problem has something to do with parking mode. It is like the front camera gets stuck in parking mode, and does not notice when the car starts moving.
I am going to move the front memory card to the back and the back to the front. I will go through the settings and verify that both cameras are set up identically. I will format both memory cards in the camera that they are installed in.
edit 3: Parking mode was off on the rear camera, but it behaved as if parking mode was on.
