So i received the sample for testing. The problem im having is the a129pro will always stay ON despite having no key in the ignition.
I installed the supplied hardwiring kit provided by them. The ground is connected directly to the vehicle chassis. Both the ACC and BATTERY (Yellow and Red) cables are connected to fuse taps. The yellow is connected to an accessory fuse while the battery is connected to the hazard lights fuse which has a constant 12v. I have tested with my fluke meter and i have 12v at all times on red. I have 0v on accessory with the key off, 12v with the key turned to accesory. As soon as i plug in the power cord to the front camera it takes 5 seconds to power on and stays on despite having the key off(out of ignition).
I do not have parking mode enabled.
I do not have the rear camera connected yet
I have the power plug feeding to the front camera body despite being mounted on the gps body to the windshield.
I have reformatted the sd card (samsung evo 128gb)
I have updated firmware via wifi to latest model
I have restored default settings twice.
Whenever i try to use the viofo app to mess with settings it seems to get stuck and become non responsive half the time.
