Looking to outfit my new vehicle for documenting accidents while driving, utilizing some form of parking mode, and possibly using content for a YouTube channel and seeing the A129 is about the same price as 2 x A119s. Just playing out the Pros/Cons and looking for what folks on the forum with more experience would pick, or if there are additional Pros/Cons to consider. Thanks!
A129:
Pros....
- 1 Micro SD to purchase
- Only 1 card to remove when wanting to pull footage
- Smaller profile rear camera
- Front and rear videos are timestamped and in sync for editing purposes.
- Less wiring that 2 x A119
Cons....
- No camera redundancy
- Lower bitrate / Lower video quality when considering front and rear together.
- If looking to push the performance of the setup with firmware found on this forum, lower thermal envelope.
- Need more expensive / better quality / twice the size SD card to process two feeds at once.
- locked to 1080 @ 30FPS when using front and rear.
2 x A119 V2:
Pros...
- If front camera fails, you can move the rear camera to the front.
- Higher bitrate / video quality when consider front and rear together.
- If looking to push the performance of the setup with firmware found on this forum, higher thermal envelope because u have processors to do the work.
- Can use slighty slower SD cards at half the size as there is one card per feed.
- Can shoot 1440p @ 30FPS in both front and rear.
Cons....
- Have to run two power cables, but no USB data cable from front to back.
- Depending on startup times of identical camera, perhaps timestamps are slightly off when editing?
- When obtain front/rear footage I need to remove and process 2, not 1 card.
- Need to purchase two cards if I don't already have them on hand.
Difference in lenses for the rear? Difference in angles? Are there other things I'm missing? Many thanks!
A129:
Pros....
Cons....
2 x A119 V2:
Pros...
Cons....
