ras07
Do not forget to return buffering to the final firmware version 1.6, you promised to do it.There are still some improvements that need to be done with V1.6. We'll inform you guys after finishing it.
What you mean ? I get parking mode timer setting revert back to 3 hrs always, irrespective of what i set. You saying on my brand new unit i got capacitor issues ? What tests are there to check if capacitor is faulty ?If it also happens when you change other settings, the capacitor may be broken.
It makes a sound before turning off, but does not say recording stopped or anything like that, in all honesty i didnt really test to see if video file the last one before turning off camera is there or not. Wondering if its really hot or cold out there will supercapcitor work reliably or not . I had bought another camera before this, ToGaurd or something, and wow its supercacitor was really good, i could get like 10 mins of use after pulling cable easy, could even power it on after been off for two or 3 days. It would keep its charge it was crazy.While camera is turned on and recording, remove the power cable. If the camera shuts off immediately, you've got a bad capacitor. If it stays lit a few seconds, and properly exits the file being written without corrupting it, then the Supercapacitor is fine.
To me, that sounds like your previous dashcam had a battery, not a capacitor. You will not get 10 minutes run time off a capacitor.I had bought another camera before this, ToGaurd or something, and wow its supercacitor was really good, i could get like 10 mins of use after pulling cable easy, could even power it on after been off for two or 3 days. It would keep its charge it was crazy.
Perhaps the A139 stops charging the capacitor when it is very hot?When testing when it was very hot, mine would turn off instantly when power pulled. Otherwise it would shut down just fine.
This is the latest firmware V1.6 Beta: https://drive.google.com/file/d/1O8p1Rzb81pndczIDs0_ub706qYOqj-_R/view?usp=sharingWhich firmware with the station mode configuration is the more stable of all?
Worth to mention it's another iteration of v1.6, specificaly "subversion" 20211008.This is the latest firmware V1.6 Beta: https://drive.google.com/file/d/1O8p1Rzb81pndczIDs0_ub706qYOqj-_R/view?usp=sharing
The error of connecting to the computer has not been fixed, the indicator is on, but there is no connection.This is the latest firmware V1.6 Beta:
Do you mean there is no file message popped on the computer when connect to it? Please use the supplied short USB cable.The error of connecting to the computer has not been fixed, the indicator is on, but there is no connection.
It is very inconvenient to pull the card every time !!
Firmwares up to version 1.6 works great with my cable !!Please use the supplied short USB cable.
