Mtrev
Is the light you’re turning on in your car or garage? Sounds odd behaviour, is the SD card ok?100% not. Cables connected to + was red & yellow. And files was in app root folder, not in Parking folder (and names was without P).
Light in garage. SD card is Ok.Is the light you’re turning on in your car or garage? Sounds odd behaviour, is the SD card ok?
The camera is receiving the signal properly as it does go into Parking Mode just fine. No issue with that at all. The issue is that occasionally it either doesn't come out of parking mode or is frozen. I can't really tell which is the case.Check your HK3-C connections and wires, including GND. From what you are describing is like the camera is not receiving the proper ACC signal to move out from Parking Mode.
The Viofo dashcam is always using the BAT for camera to record, no matter if is in driving mode or parking mode. The ACC wire is used only to tell to the camera to enter in Parking Mode or not.
If you are sure the HK3-C is properly installed then is possible the HK3-C to not work properly.
I don't see how it can be a dashcam fault, it must be a powering problem.
The same issue here. It's definitely related at least to firmware.The camera is receiving the signal properly as it does go into Parking Mode just fine. No issue with that at all. The issue is that occasionally it either doesn't come out of parking mode or is frozen. I can't really tell which is the case.
My A139 has been reliabe for 2 years without any issues.I find A139 unstable. One day it works fine, the next day it restarts several times while driving for no apparent reason.
I find A139 unstable. One day it works fine, the next day it restarts several times while driving for no apparent reason. I have to have my smartphone connected to Wi-Fi at all time to know if the dashcam is working because I already had a situations where it turning off by itself and even one time before my (new) car was hit in the parking lot and the A139 didn't work at this time.
I'm tired of connecting via Wi-Fi to see if it works. I had previously learned the painfull lesson not to buy Chinese and I made the mistake again. Seeing "made in China" on the box, I should have sent it back, but I didn't do it, thinking that good appearance implies a good quality.
Agreed. We have three (3) 3-cam setups in 3 different vehicles with 3 different memory cards running on Viofo's hardwire kit. Initially, they all worked fine. Then they started to have random freezes, wifi problems, etc. One of them still mostly works. Two of them are no longer discoverable on wifi, so we can't adjust settings. One of them can't even be powered off via the buttons on the unit - and that's actually the replacement unit Viofo sent us. We have tried new memory cards, swapping to the 12v socket adapter, unplugging all but the main cam, old firmware, new firmware, etc. These things are just straight up garbage and I would never buy another.
Does Viofo provide you free products?The Viofo dashcam didn't worked for you. For other thousands of people it is working. Because if all Viofo buyers would have exactly your problems the Viofo company would disappear from the market or at least this model.
Good luck with your new camera, we hope you will not post also about it as having problems.
