A139 turns off by itself after starting the car
wael
saudai
Saudi Arabia
I had a problem that the camera turn on then turns off by itself after starting the car
And it need to turn on from the Camera start button
i use Hardwire Kit
Is there a way to make the camera work automatically?
kamkar
Denmark
10 years, many dashcams
It should work automatic, have you tried to use the regular power source to rule out it is not the camera ?
W
wael
saudai
Saudi Arabia
thanks
Today I will try using a cigarette lighter adapter
But using the Hardwire Kit is the best
kamkar
Denmark
Yes, but just to rule out camera problems, if it work with the standard power kit then the HK3-C hard wire kit must be bad in some way.
I cant say i have heard of your problem before, so all i can think of are wrong installed hard wire kit, or defective kit.
Nigel
Wales
Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
Maybe increase the startup timer setting.
W
wael
saudai
Saudi Arabia
It works well with cigarette lighter adapter
I think we should re-search for more suitable fuses or that the problem is from HK3-C hard wire kit
kamkar
Denmark
Yes, if that work fine there must be some issue with hard wire kit connections or the kit itself.
Many modern cars can be a bit problematic for hard wire as electronics are smart.
W
wael
saudai
Saudi Arabia
The connections are correct, but I will change the fuses that I used. Perhaps the fuse functions are the reason
Yes, the car is modern
SawMaster
SC
Numerous and ever-changing
Almost certain to be in the way the circuit (fuse) you have tapped into behaves. Try other fuses.
It gets tougher every year to find the correct fuses to tap into with cars, as they're all going to computer-controlled power schemes.
Mtrev
Shropshire
Check the voltage at the fuses when the camera turns off to make sure they both still have battery voltage.
could it be the voltage instability during starting causing the issue which is where I believe the start up delay Nigel suggested comes in to play.
W
wael
saudai
Saudi Arabia
thanks all
After re-checking the fuses and voltages, I discovered that I am using the fuse of the AC, and after turning on the air conditioner, the voltage drops and the camera turns off.
I used another fuse and now it's working fine
