flint350
I have pre-ordered the A229 Pro from the Viofo website to replace a Blackvue 970X that is malfunctioning. I have the BVue hardwire cable running into the trunk where it is connected to a dedicated EcoFlow battery for long parking use, etc. Blackvue is now using a 3 wire cable that terminates in a 3.5mm plug that goes into the front camera. Viofo also uses a 3 wire cable that terminates in a USB-C connector to the camera. To avoid a full removal and new install of the power cable all the way to the trunk, I was hoping I could cut off the 3.5mm connector from the BVue and splice it onto the Viofo USB-C connector. Both use same power output and the only difference I see is that the RED/Yellow wires are reversed in function (Power-Batt). So, a splice of red-to-yellow and yellow-to-red would hopefully work to power the Viofo by USB-C, using the BVue pre-installed cable. Anyone know why this wouldn't work?? If not, I will just have to undergo the removal and a new install, but this would be so much simpler. Thanks for any input.
