A329 2CH (2024) + BP100 Bluetooth Pairing Issue
PeterGreefent
Almeria
Spain
Yes, I believe it will happen. I just don't know the scheduling priority this feature has in the development group. It will need a firmware change to the BP100 and it will need a firmware change to the dash camera to know to look for the BP100 Bluetooth broadcast. For the A329S, v2.1 firmware has been stated as the version that will first see this feature.
On Feb 1, 2026 @VIOFO-Support stated this:
The two things you gain when using the HK6 are the voltage level [stamp] that can be placed in the video status line and it can be used with the "Voltage cut-off" feature [A329S series of dash cameras only so far].
The A329S voltage cut-off feature voltage selections are geared towards an internal combustion engine [ICE] vehicle. If you want one of those voltage settings to be the point when the A329S switches from the standard parking mode [Auto Event Detection, Time-Lapse, or Low Bitrate] to low power impact detection parking mode [hybrid parking mode configuration], then it can still be helpful. It depends on how you drive/park your vehicle and how you want to use the battery pack power.
If you decide to use a HK6 with the BP100, it's probably best to get the modified version of the HK6 [from VIOFO] that allows the HK6 low voltage cut-off feature to be disabled. That will allow the dash camera to be powered for a longer period of time. The production HK6's low voltage cut-off minimum setting of 11.8V will prevent the dash camera from taking full advantage of the BP100's stored charge. The BP100 can continue to deliver power with a voltage level into the low 10-volt range before it turns off the power to the dash camera [or dash camera hardwire kit in this case]. The amount of time that can add to a parking mode session can vary based on the parking mode used.
The BP100 includes the USB-C dash camera power cable that supports parking mode operations. That BP100 USB-C dash camera power cable does not have a low voltage cut-off feature nor does it have a Bluetooth broadcast of the voltage like the HK6. You only need the HK6 if you want access to the voltage info.
Buenos días .
Yo tengo el modelo de dashcam A329 .
Este modelo es compatible con lectura de voltaje en pantalla con HK6?.
Por otro lado haces referencia a un cable HK6 sin corte por descarga de batería .
Yo estaría interesado en dicho cable ya que uso la batería Viofo BP100 .
Dicho cable modificado HK6 veo que no lo vende oficialmente viofo , entonces como se puede solicitar y que lo envíen ?
Yo resido en España y nuestro distribuidor es Viofo.nl
Por otro lado hay rumores de que la lectura de voltaje se va a implementar a los que tenemos baterías BP100 sin necesidad del cable HK6.
Como está ese tema de implementación actualmente , se saben fechas ?
Saludos y muchas gracias por la ayuda .
Buenos días .
There is no need for HK6 if you use BP100, the hardwire cable included can support parking mode without issue. And the 329S support showing battery capacity already.
Pero yo no tengo el modelo a329S ....
Tengo el modelo A329 .
Este modelo que yo tengo no tiene la capacidad de ofrecer lectura de voltaje de batería en grabación ??.
No se puede implementar con una actualización de Firmware ?
Only A329S support showing BP100 battery capacity currently.
Buenos días .
The latest BP100 firmware [V39] already supports publishing the BP100's charge level percentage to a compatible VIOFO dash camera model. The A329S/T/TC/WW series firmware already accepts and displays that battery pack charge level percentage and it also can use that in the parking mode vehicle battery protection settings. I have not checked the A329 with the recently released V2.0_20260812 firmware to know if it will display the battery pack percentage.
You don't need to use the HK6 with a BP100 battery pack since the BP100 is already supplied with VIOFO dash camera power cable that does not have a low voltage cutoff feature.
Entiendo eso que ha querido decir desde el mensaje anterior.
Pero considerando que la A329 y A329s a nivel de sofware y parte del hardware son muy similares .
Añadir esa característica solo depende de una actualización del Firmware que añada esa función .
O acaso el modelo A329S tiene un hardware dedicado a lectura de voltaje que el modelo A329 no tiene ?.
Sinceramente veo muy injusto que compre una dashcam que me costó 400€ considerado el buque insignia de Viofo y lo más avanzado y 1 año después resulta que ni puede ofrecer el voltaje en pantalla de la batería ...
Esto me hace replantearme si las próximas compras de cámaras las haré a otro fabricante .
Y bueno ya no hablemos de el modo de estacionamiento híbrido , el cual habéis dejado fuera a la A329 ... Sinceramente veo vuestra política de unos años hasta ahora ,sacar cada 2x3 modelos con mínimos cambios pero mejoras sutiles para obligar a cambiar de cámaras a sus usuarios y esto no lo veo correcto .
Algunas de estas características si queréis las podéis implementar en los firmwares de actualización , pero por lo visto os interesa más que la gente gaste el dinero en cámaras ,teniendo la anterior menos de 1 año .
Está es la respuesta que esperaba.
Comprensiva y no descartando posibilidades .
Yo actualice hace unos días la mía vía OTA ,mediante la app nueva que es de control dual de batería y dashcam...muy buena por cierto la app.
Además me sorprendió que la propia App me ofreciese una actualización OTA del modelo A329 , el cual desconocía ya que la última oficial era de Enero de 2026.
Pero sinceramente me metí en la configuración de la cam mediante la app y no me pareció ver nada relacionado con el voltaje de la batería .
Así que dudo que lo hayan implementado en la A329 , de todas maneras dentro de un rato iré expresamente al vehículo y revisaré 1x1 las opciones de configuración en la App para confirmar o descartar esa opción .
En caso de no estar incluida me pareceria un despropósito total , ya que la A329 no es una dashcam de 100€ ni la batería BP100 una powerbank de 50€ como para no ofrecer algo tan sencillo y básico como el voltaje en grabación .
Y por supuesto si el modo de estacionamiento híbrido no lo implementan también es por temas comerciales , por qué el tipo de estacionamiento híbrido no lo veo algo que a nivel de hardware requiera algo extra o tenga el modelo A329S respecto al modelo A329
Me autocontesto .
He ido al vehículo y he mirado en las opciones de configuración de la app de viofo y en el menú me deja señalar y pone como predeterminado " voltaje del vehículo " después he comprobado en el propio menú de la dashcam y efectivamente también figura seleccionado ese parámetro .
Pero contrariamente a lo que indica el software , no indica por ningún lado en la pantalla ni grabación el voltaje de la batería ni vehículo ni nada .
Osea en el menú del software aparece seleccionado pero realmente no da ese dato por ningún lado .
Puede ser un bug del Firmware ?
Un problema del cable suministrado con la batería BP100 ?
Puede ser que aún estando esa opción en el software aún no se haya implementado del todo y este en desarrollo ,?
En este último caso de ser así es algo chapucero incluir una opción que no surte efecto por ningún sitio .
The vehicle voltage value is provided by a HK6 hardwire kit when used to power that dash camera via Bluetooth data.
The BP100 battery pack charge level is broadcast via Bluetooth and is presented as a percentage for dash camera models that support it.
Osea la dashcam debe llevar dispositivo incorporado de Bluetooth para recibir esa información desde la batería ?...
En este caso si fuese así el modelo A329 no dispone de dicho dispositivo bluetooth? Y por eso no recibe la información de la BP100 ?..
Si este fuese el problema de mi cámara A329 la única solución supongo que sería adquirir un cable HK6 pero tendría el inconveniente del corte de energía proporcionado por el cable HK6 y desperdiciaría parte de la autonomia de la BP100 .
En caso de adquirir un cable HK6 si me mostraría el voltaje de la batería BP100 en pantalla ?
En publicaciones anteriores de ustedes he leído que existe un cable modificado de viofo tipo HK6 que no tiene restriccion de corte de energía pero si ofrece voltaje en grabación y pantalla, estoy equivocado en esto ?
Ese cable de existir , como se podría adquirir en EU , ya que nuestro distribuidor es Viofo.nl .
Perdona tanta pregunta , pero me da pena e indignación gastar tanto dinero en una dashcam último modelo y en menos de 1 año pasar a ser una cámara obsoleta con apenas soporte y mejoras de software y que se centren incluso en otras como el modelo A329S actualmente más económicas incluso .
The older A329 dash camera does have Bluetooth support [for example it works with the BTR200 Bluetooth remote like other models]. The A329 was released in September 2024 and the A329S was released mid-2025.
The HK6 hardwire kit and the BP100 battery pack currently use Bluetooth to send [HK6: input voltage level, BP100: battery charge percentage] data to the VIOFO dash camera they are paired with.
The A329S and A119M Pro did not have support for receiving the BP100 battery charge percentage level until firmware updates were made available in the past few months.
It's up to VIOFO to decide how many older models to add the VIOFO battery pack charge percentage level feature to depending on sales and support needs for current models.
There is a version of the HK6 hardwire kit that has the low voltage cut-off feature disabled when you select the "12.4" voltage setting on the HK6 module. You would need to contact VIOFO directly with a support ticket to ask them to send/sell you the modified HK6 hardwire kit. If you successfully obtain the modified HK6 which allows the low voltage cut-off feature to be disabled and you connect that HK6 to the BP100, the voltage data provided by the HK6 to the dash camera would be the output voltage level from the BP100.
Maravillosa y detallada respuesta .
Muchas gracias por su paciencia y tiempo dedicado .
Efectivamente estoy torpe hoy ..tengo el botón remoto por bluetooth para mí cámara y le he preguntado absurdamente si mi cámara no tiene dispositivo bluetooth???... A veces uno no piensa lo que pregunta .
Pues tendre que crear otro ticket de petición a soporte de Viofo para ver si quieren crest una actualización de Firmware que añada los datos de porcentaje de batería de BP100 o si voltaje .
Pedirles el cable HK6 modificado y que le lo envíen supongo que será difícil , ya que el fabricante si no me equivoco no es de la UE y sería una exportación con coste de aranceles y posibles problemas.
No sé si accederían a tramitar la entrega al distribuidor oficial en EU viofo.nl y ellos enviármelo a mí ..pero supongo que igualmente supondria un lío.
Bueno voy a intentar exponerles el problema y posibles soluciones a ver qué me contestan.
De nuevo muchas gracias por su ayuda y consejos .
Si resuelvo este problema o me dan una solución factible , la comunícare aquí por si a alguien le sirviera de ayuda .
Since you use BP100, there is no need for HK6 hardwire kit. You can check this blog for more details: https://www.viofo.com/blogs/viofo-car-dash-camera-guide-faq-and-news/bp100-hk6-dashcam-app-setup
The HK6 support showing vehicle voltage, while battery app support showing battery level.
For the BP100 user, the battery capacity data is important since the camera consume power from BP100 directly after your car is parked and you do not need to know the vehicle voltage in this case.
Ahhh ....
Ok.
Esto es lo que realmente quería leer y que me aclarasen .
Entonces entiendo según las instrucciones que con el kit de conexión incluido con el kit de batería BP100 mi dashcam A329 mediante vinculación con la app en la sección de la batería BP100, hay una opción para vincular por bluetooth la batería BP100 a la Dashcam A329 y una vez realizado ese paso en la cámara saldría el aviso de la vinculación de la batería por bluetooth y ya ofrecería la carga de salida de voltaje de la batería BP100 y ya podría monitorear ese dato en las grabaciones .
Esto es así como lo explico , lo entendí bien ? ...
Si es así me alegra el día .
Ya estaba pensando mal de Viofo precipitadamente .
Por lo que veo ha sido un mal entendimiento entre nostros ,en parte por la diferencia de idiomas y las nuevas funciones añadidas de la app y si desconocimiento .
Lo probaré en un rato y comprobare que ese dato lo da correctamente .
Saludos y muchas gracias.
A ver , vuelvo del vehículo ....y sinceramente o ustedes ,tanto atención al cliente de Viofo mediante ticket ,como usted no me están entendiendo lo que pido , cosa que otros compañeros del foro han comprendido perfectamente .
O ustedes no saben explicar las cosas y me remiten a un blog donde por cierto salen instrucciones que realmente no cumplen con la realidad .
A ver , estoy pidiendo voltaje de salida en grabación de cámara A329 y les pregunto que si necesito un cable HK6 modificado para que no corte voltaje de batería BP100 ....?
usted me contesta que no necesito HK6 por qué pack de baterías ya contiene el suyo y con ese ya ofrece nivel de carga de batería en App viofo ....a ver... Yo estoy pidiendo voltaje de salida de batería BP100 , no quiero ni me interesa la carga de la batería del automóvil , por la simple razón de que compre su pack de batería para evitar la descarga de la batería del automóvil .
Con lo cual olvídense del monitoreo de la carga de la batería del vehículo , quiero la de la batería BP100 en la grabación de la cámara A329 .
Me remiten a un blog donde explican que la serie A329 puede recibir mediante bluetooth a la app viofo el % de carga de la batería BP100 , esto es correcto y lo se desde hace meses .
También dicen en dicho blog que con el cable suministrado con la batería BP100 y la batería se vincula a la dashcam serie A329 y ofrece nivel de voltaje de salida de la batería BP100....esto es falso , lo he comprobado por más de 1h dándole mil vueltas a los menús , reset de dashcam ,desvincular dashcam , batería ,etc, vincular todo de nuevo .
Ni la dashcam en ningún momento hace referencia a ningún tipo de vinculación con la batería BP100 ni en el menú de la app dentro del apartado de batería pone que tiene vinculada la dashcam A329 .
Y ya la tercera opción , que es gracioso , pero usted me desaconseja que es el cable HK6 si pone que ofrece el voltaje de salida de la BP100 , aunque paradojicamente después en el cable HK6 pone que es compatible con A329S no pone nada de A329 .
Osea esas imágenes e instrucciones no sirven de nada con la dashcam A329 .
Así que sinceramente , usted que es de soporte de Viofo me marea desaconseja do el cable HK6 y que use el cable suministrado por BP100 , y el cable BP100 no suministra los datos de voltaje que requiero .
El firmware que ustedes han actualizado a la dashcam A329 no añade nada referente a vinculación con la batería BP100 ni dato de voltaje de salida de la batería BP100 por bluetooth.
Todo esto solo me ha servido para perder el tiempo y marearme .
Exceptuando los compañeros que desde el principio comprendieron la situación y me aconsejaron correctamente un cable HK6 modificado por ustedes que anula el corte de voltaje de la batería BP100.
Les subo un par de fotos de mi app viofo con la vinculación de la batería y dashcam y Firmware , verán que las imágenes del blog de instrucciones no corresponden , en ningún sitio pone que la batería este vinculada a la dashcam A329 tal y como si ponen en su blog de instrucciones .
@PeterGreefent
If you still need help, I think I can explain the miscommunication, (lost in translation).
Would you be so kind to start a new / separate thread called;
Please make sure you start the new thread in the correct camera section, because I think that’s part of the miscommunication, (see attached screenshots).
A329 2CH (2024)
A329S 3CH (2025)
Are two completely different cameras with two completely different firmwares.
-Chuck
@PeterGreefent
A329 2CH (2024)
A329S 3CH (2025)
-Chuck
Si ,ok...
Entiendo el malentendido .
Por otro lado es penoso que el buque insignia que empezó la serie A329 ,su sección este escondida y perdida .
De todas maneras abrir otro tema con este asunto ,te lo agradezco la recomendación y ayuda.
Pero está claro que Viofo a dejado tirados y abandonados a los clientes que compramos este modelo.
Solo hay que ver qué modelos muy inferiores en precio y características tienen compatibilidad con el cable HK6 y el modo híbrido ,etc...y el A329 ni se la menciona.
He gastado mucho dinero en Viofo y tenía pensado comprar la ampliación de batería EP100 , pero me parece que me ahorraré el dinero .
De todas maneras aunque está sección no es específica de A329 tampoco lo es de A329S , no debería haber confusión por qué mis dudas y consultas son referentes a la dashcam y la batería BP100 , en este caso está dentro de un tema específico de la sección de batería Viofo .
Escribí aquí inicialmente por qué en este hilo hacen referencia a un cable HK6 modificado sin corte de energía para las dashcam A329...y eso estaba consultando , pero parece que se habló y no existe realmente para Viofo .
@VIOFO-Support you're advising an A329 user against using the HK6 hardwire kit since the BP100 will transmit the charge level percentage to the dash camera via Bluetooth. The misunderstanding seems to be that the user has an A329 [the older model] not the newer A329S series. If VIOFO adds [or has already added in an unreleased firmware version] the VIOFO battery pack charge percentage feature to the older A329 model firmware, then your advice is correct.
I just upgraded my older A329 unit with the latest v2.0_260812 firmware. The "Stamp" setting only includes a "Vehicle Voltage Value" option with no option for the "Battery Pack Capacity".
I just checked an A329S unit with its latest v2.2_260815 firmware installed. The "Stamp" setting includes the "Vehicle Voltage Value" AND the "Battery Pack Capacity" option.
If the user's objective is to present the voltage value in the A329 status line or use it in configuring the A329 hybrid parking mode "Vehicle Battery Protection" feature, the only option [for now] is using the HK6.
If the A329 firmware is updated to include support for the VIOFO battery pack Bluetooth transmission of the battery pack charge capacity, then the user can use the dash camera power cable included with the BP100 instead of using the HK6.
Efectivamente ...
Totalmente es lo que me pasa y sigue pasando después de actualizar .
Una actualización a mí parecer inútil a nivel de poder sincronizar el voltaje de salida de BP100 con el modelo A329 por bluetooth.
No han incluido esa opción ni mejora , actualizan firmwares del resto de cámaras incluyendo esta ventaja y la A329 dejan olvidada , después de gastar 430€ cuando salió y recientemente casi 300€ en una batería BP100 y multitud de accesorios extras y una dashcam que es unas de las TOP y más caras de Viofo actualmente incluso , no incluyen algo tan básico como dato de voltaje de salida de BP100 en pantalla de dashcam y grabación, por qué no quieren añadir un firmware que sincronice el bluetooth de la BP100 con la A329 y sus correspondientes opciones??
Y para colmo me hacen perder el tiempo en comprobaciones inutiles leyendo blogs de instrucciones equivocados y perdiendo el tiempo en configuraciones en el coche.
Y para colmo la contestación del ticket que envié a soporte de Viofo.com, es igual de inútil ...siguen cerrados en que no monte el cable HK6 por qué ya tengo el de la BP100....
Y les expliqué que mi modelo es el A329 ....increíble que sigan confundiéndola con el modelo A329S ....
es que no conocen el modelo A329 sin la S al final ?? ...
En fin , muchas gracias por entenderme y molestarte en actualizar tu dashcam y ver cual es el problema que intento explicar desde hace varios días ...
Aunque tú lo entendiste a la primera que lo leíste la primera vez .
Perdona si sigo con este tema en tu hilo .
Solo quiero notificarte sobre la última contestación recibida hace unas horas de soporte de Viofo.com respecto al Ticket que les abrí sobre este asunto hace unos días .
Ojo , el ticket está abierto en todo momento especificando mi modelo exacto de dashcam tanto en las opciones seleccionables previas , como a nivel explicativo dentro del texto de mis explicaciones y argumentos , osea no es mi problema el que ellos estén dando contestaciones inválidas .
Pues resulta que la contestación me dice exactamente lo mismo que soporte de viofo aquí en el foro ...
Y para empeorar aún más , me manda capturas de la pantalla de la dashcam a modo de ejemplo observándose el dato de % de batería BP100 y las opciones seleccionables de corte de la batería dentro de menú de la Dashcam ......
Lógicamente todas esas imágenes no corresponden al modelo A329, corresponden al modelo sacado posteriormente el A329S .
Y me ha remitido al mismo blog de instrucciones de uso de la app y cables de conexión de la BP100 que me remitió servicio técnico de aquí del foro .
Osea deduzco que no saben ni que el modelo A329 no implementan esas opciones y para colmo lo confunden con el modelo A329S .
No entiendo está falta de conocimiento de sus propios productos por parte del propio servicio técnico de Viofo y para colmo que ni sugieran que hay un firmware en camino que implementara estas opciones o de no estar en sus planes lo consideren seriamente hacer .
Nunca en mi vida me había pasado nada parecido con un producto o fabricante de reputación medio decente y aún menos en productos de tan alto valor.
Estoy casi apunto de comprar la ampliación de batería EP100 .
De echo solicité un cupón de descuento a viofo.nl por qué en EU no han aplicado el descuento de 20€ en si precio .
Y dicho cupón se caduca mañana domingo , asi que según vea el desarrollo de este tema entre hoy y mañana lo compraré o renunciare definitivamente a productos de Viofo, exprimire todo lo que pueda lo que tengo de ellos y cuando renueve dashcam mirate otros fabricantes .
Obviamente si me viese obligado a renunciar a los productos de Viofo por abandono de actualizaciones que otros productos de menor nivel o igual si están recibiendo , sintiéndolo mucho lo publicidad hacía ellos en las redes y medios donde participo no sería precisamente positiva, y nome gusta llegar a este tipo de comunicaciones , pero llevo muchísimos años con Viofo , no es mi primer producto de ellos está dashcam , llevo mínimo 15 años usando sus productos .
No soy novato en esto , de echo estoy perfectamente cualificado para realizar completamente las instalaciones de sus productos en vehículos con total profesionalidad y seguridad .
De ahí que desde el principio aunque haya confusiones por tema de traducciones , sepa lo que está pasando en todo momento y este explicando los síntomas y posibles soluciones .
Pero no es justo que está dashcam reciba una actualización con menos tiempo que el modelo A329S y por el contrario el modelo A329 no metan nada referente a control y datos de carga de la batería BP100 ni modo parking Híbrido , etc...una vergüenza .
