joysleep
What's the easiest way to update the dashcam?
Two Options:What's the easiest way to update the dashcam?
Great will do it on the weekend.Two Options:
1.) OTA
2.) Manual With SD Card
Follow instructions from official VIOFO website.
https://www.viofo.com/pages/firmware?s=A329S
So on your testing can you double check that when it's successfully paired to the battery pack.BP100 paired with A329S.
Firmware: V2.1 260702
See attached screenshots.
Hi
.Viofo team.
Is there anyway you can test out or fix the issues with the bp100 battery.
Can you test whether the Bluetooth app on your phone still works when you have paired this to the dashcam to work with hybrid parking?
Look forward to your response.
I don't know how to do that..
You have to use the @ symbol, like so...
@viofo
@VIOFO-Support
That way they get a notification that they have been mentioned. š
@viofoOK something weird is going on.
It's like either the phone or the dashcam can be paired to the battery pack but not at the same time.
So once I got my phone to connect it said battery not found when trying to set the cut percentage.
When I somehow got the dashcam and the battery to pair my phone gets locked out and can't see it in the app.
So upon further testing I found when my phone was connected to the battery pack the dashcam says "no paired battery pack found".
So I'm guessing to use this feature we sacrifice the phone to be able to connect to the Bluetooth because I can't get both to work at the same time
I did this multiple times and have gotten the same results.
The only way I can get my phone to connect is if I manually turn off the battery pack then turn it on it will pair to my phone.
Then I realised it's now lost connection to the dashcam and so your battery percentage cut off won't work unless you pair that back up again.
Anyone else finding this?
It is normal. But this will be optimized in the future.
Sorry what do it mean it's normal?It is normal. But this will be optimized in the future.
It is not the issue. Currently, they connect via pairing, so only one device can be connected at a time. Future connections will use a broadcasting method, but this requires time to optimize.Sorry what do it mean it's normal?
As in were the team aware of the issues?
Oh right.It is not the issue. Currently, they connect via pairing, so only one device can be connected at a time. Future connections will use a broadcasting method, but this requires time to optimize.
