A900 Ultra Parking Mode: What Actually Changed vs. T800 & 4K Omni?
Becky_70mai
Melbourne
Parking Mode is one of those features that tends to be overlooked until an incident actually happens. For the A900 Ultra, the focus was not simply on adding more parking recording, but on improving what gets captured and how efficiently the system operates.
1. Pre-recording on both channels​
Compared with the T800 and 4K Omni, the A900 Ultra's collision detection supports 5-second pre-recording on both front and rear channels.
This means the footage doesn't start with the impact itself. The few seconds leading up to the event are also captured, providing more context around what happened.
2. Motion Detection with pre-recording​
The same approach is applied to motion detection. When motion is detected around the vehicle, both front and rear cameras can capture the 5 seconds before the trigger, rather than only recording what happens after detection.
For parking incidents, the context before the event can sometimes be just as important as the event itself.
3. Lower-power parking operation​
Another change is the move toward lower-power operation, with power consumption as low as 5 mA in the relevant low-power state.
The idea is straightforward: reduce the power required while the vehicle is parked while using quick-start behavior to respond when monitoring is needed. This makes longer-term parking monitoring more practical, particularly when the vehicle is left parked for extended periods.
4. Faster footage access with Wi-Fi 6​
The A900 Ultra also upgrades connectivity with:
  • Wi-Fi 6
  • 2.4GHz + 5GHz
  • BLE
  • Up to 45 MB/s transfer speed
For parking footage, this matters less as a specification and more as a workflow improvement. If you need to review or save a clip from the camera, faster transfer means less waiting for footage to download to your phone.
The overall approach​
The A900 Ultra's parking-mode upgrades are mainly focused on three areas:
Capture more—use less power—access footage faster.
Compared with the T800 and 4K Omni, the biggest change isn't simply having another Parking Mode option. It's how the system handles pre-event footage, dual-channel coverage, low-power operation and footage access.
Looking good Becky,,,,,,,, Dashcam too 😉
Can you share how fast the system boot from low power parking mode
My preliminary test results show that the A900 Ultra starts recording in just under 2-seconds [1.93 seconds in my tests] after a triggering impact event.
Thats not bad. 👍
Thats not bad. 👍
Vastly improved times compared to the older T800 and X800, which AFAIK used the on-board Novatek algorithms for human detection to trigger these events. As it's an updated Novatek chipset in the A900 & A900 Ultra, I would presume a lot of big upgrades are there.
Do you have the relevant values for T800 and X800? Just for reference.
Was that with all the available parking options including the "Motion Detection with pre-recording"?
Mine were timed values in my T800 and X800 unboxing threads here on DashcamTalk forum. Managed to dig up the links to the timings here.
Do note that as mentioned in the posts, that they are due to the native phase detection autofocus support on the Novatek chipset itself. Others have mentioned that it is 70mai's "technology of human detection", but AFAIK they just took the native support off the board itself and called it a day.
No, the 1.93 seconds between the impact event and the start of the recording is with only collision detection parking mode enabled with pre-recording disabled. To achieve the low power 3-to-5 mA power draw state, the pre-recording [buffering] feature must be disabled and the A900 Ultra was powered by a UP03 hardwire kit.
If I'm only ever going to be using the 5mA low power parking mode, is there any point of getting the battery pack?
Such low power draw isn't going to stress the cars battery anyway, so may as well hardwire it with the UP06 kit right?
Yeah if it is buffering, needless to say it is also using more power.
The very low power use still play into 2 factors, the size of that battery and time.
Also and my primary focus as i do not drive a lot, the time it take to recharge my battery, which with a low power use mean i can replenish what is lost in a shorter drive
TBH i would have to admit i would hate having to drive 45 minutes every day to keep my battery topped up, also these days with gasoline price and me being on a meager pension, well it would be expensive.
My car wasent even started yesterday,
