ADAS chimes on the Qvia QR790?
traficam cape town
Cape Town
South Africa
Crosstour CR900, Stealth Dash Cam & Qvia QR790
Anyone has an idea what the different ADAS chimes are on the Qvia QR790? I kinda figure out some but just want to know if there is a sample audio list.
Ness
Sydney
This Dashcams makes way too many noises, it chimes for lane departure, if you get too close to the back of another vehicle and also chimes anytime the GPS signal is not constant, which happens to be quite a lot. I ended up having to turn the speaker off because it was so annoying.
traficam cape town
traficam cape town
Cape Town
South Africa
Hi Ness, the sounds/chimes you hearing from the Qvia/Lukas dash cam's built in ADAS 2.0 (Advance Driving Assistance System). Here is the list of sounds and different meanings. 1.) Tin tin tin tin, tin tin tin tin (LDWS - Lane Departure Warning) 2. Ding Dong (FCWS - Forward Collision Warning) 3. koo koo (FVSA - Front Vehicle Sensor Alarm when standing still movement detected from either car in front moves off or pedestrians crossing) 4. TIRURU (WiFi Off - Within 5 minutes of turning on the car) 5. Taramm WiFi On - Automatically when starting the car) 6. Tin Tunn (Event/G-Sensor - Sensitivity can be changed) - Travel Safe !
Ness
Sydney
I turned LDWS, FCWS and FVSA off and it still chimes all the time. In addition to that I am regularly unable to connect to the unit via wifi and I have to reformat the sd card before it will work again.
Dashcammad
Mine made the same noises with everything set to be on or off. I could not see any way to silence the thing and it kept re-starting while I was driving (this seems not uncommon for many makes and models and is potentially easy to fix by hassling the manufacturer to get their firmware right). Ultimately it became an unused spare which is a pity because I think that if you take away the musical accompaniment then this camera is one of the very best out there.
