The biggest problem with things designed to assist you in doing a job, or to do that job for you, is that when they fail you will be unprepared to handle it and so inexperienced in having to deal with the problem yourself unassisted that you are almost certainly bound to fail
I do like ABS, but you must still drive as if your car doesn't have it or you will end up in trouble sooner or later. The rest of today's driving gadgets are actually working against you as you become reliant on them to the point of your failing whenever they do.
Do you really think there's any good in trusting what is a barely functional consumer grade device which is built to the lowesrt price point to keep you safe on the roads when even the most expensive and well-engineered systems can't always do that? I trust my dashcam to record video and audio and nothing more, because that is all it does with a reasonable level of reliability. I can handle the rest better than it can
