Have you done a comparison of adhesive tape vs Blendmount video quality though?Blendmount for my money.
See my install and comments here:
https://dashcamtalk.com/forum/threa...ra-post-your-pictures.502/page-61#post-533658
I ended up completing this experiment myself (set Youtube quality to 4K):No, not next to each other in the same vehicle at the same time.
My opinion is based on experience with my install vs. the complaints of others using adhesive mounting.
I've never seen a side by side mounting method comparison like that.
Which do you think is clearer?
Setup:
Kudos for taking that on! That's a nice, super clean install.
Honestly, the vids look the same to me. Need a worse road to make judgement!
IMO, the adhesive mount is most likely just as good as the Blendmount until the adhesive starts softening up in the summer heat. Or the windshield vibrates from cranked-up music.
If you find the BM vibrates more than the adhesive mount, I suggest checking your mount location and make sure that the fasteners are secure. You can't move mine with a hammer.
I always prep the surface by using an alcohol pad, then holding the camera firmly in place by applying pressure for about a minute. I have never once had any camera loose adhesiveness to the windshield.
Me too. I acknowledge that YMMV. I live in southern Arizona. Stuff stuck to windshields falls off around here all the time because of the blast furnace heat, no matter how good the prep. That was my primary motivator for getting the BM.
Based on your video comparison, and my own experience, I find that adhesive mount gives the best result for the least amount of vibration.Which solution would have lower vibration (and hence better video quality) - Adhesive or Blendmount?
The dashcam is BlackVue DR900X-2CH if that's relevant.
Your Blendmount still does a pretty decent job though but Ive found out that the longer the mount arm the worse it gets. I've eliminated those suction cups all together long time ago for a few reasons.
1, unwanted vibrations
2, bulkier setup
3, more noticeable or less stealthy
4, falling off the glass on hot weather regardless of how much I cleaned both surfaces.
5, you end up seeing more dashboard as well as more unwanted light reflection from dash.
All of that outweigh the benefits for my needs but others may find it different and that's ok.
I really don't think it is unless you're breaking a dozen other laws and the cops are trying to charge you with everything they can find. If you have it mounted between the rearview mirror and the windshield I find it hard to believe the judge would uphold any ticket since the rearview mirror is already obstructing that portion of the windshield. In a lot of places, cops barely respond to petty property crimes. I can't imagine them caring about what is mounted on your windshield.Is this enforced?
I can't speak for the reputation of this site, but it appears most states outlaw dash cameras mounted on the windshield. Is this enforced? I don't know. But I guess for anyone not wanting to run afoul or face a possible ticket, a Blendmount or alternative setup may be the next best things.
Are Dash Cams Legal? | RatedRadarDetector
While dashcams undoubtedly make driving safer, navigating the dashcam laws between different states can be confusing. In this article, I'll provide an overview of the specific dashcam laws in each state. Dash Cam Laws By State Including Restrictions. Alabama Alabama prohibits any electronic...www.ratedradardetector.org
As dashcams gain popularity everyday here in the states, I haven't heard any complaints in here or anywhere else of anyone getting a ticket for having a dashcam mounted on the windshield. I am not concerned of getting a ticket as long as I know I keep my line of sight unobstructed and one must use common sense when installing these things.I can't speak for the reputation of this site, but it appears most states outlaw dash cameras mounted on the windshield. Is this enforced? I don't know. But I guess for anyone not wanting to run afoul or face a possible ticket, a Blendmount or alternative setup may be the next best things.
Also I don't see how a Blendmount would prevent anyone from getting a ticket. If the policeman happens to be an a$$hole he will give you one regardless of the way it is attached.
L | Alternatives to Adhesive Mount? | Dash Cam Discussion | 7 | |
K | Any advice for installing adhesive mount cameras? | Dash Cam Discussion | 4 | |
Quickest/easiest way to remove 3M adhesive tape from windshield? | Dash Cam Discussion | 6 | ||
P | Better adhesive mounts? | Dash Cam Discussion | 15 | |
J | Dashcam adhesive | Dash Cam Discussion | 13 |
