kamkar
- Oct 11, 2013
- Denmark
- +1 decade, many dashcams
So today i took the 0906 apart and redid fucus with the camera connected to my TV with a HDMI cable.
The process was sort of uneventful, but i will tell why sort of later.
First taking apart the 0906, it is actually not that bad, even when i did the same for my much similar 0806 a long time ago.
But you be wise to pay attention to how the things line up when taking it apart, and watch out for the little steel ball that are the "click" part of the horizontal adjustment.
So after taking it apart i was left with the 2 connected PCB boards ( disconnected the LDC screen from the lot )
So i had the 1 half shell and then the plastic ring that's the other part of the horizontal click adjustment.
And so i was ready to tweak the focus after unscrewing the lens and cleaning up the thread on it.
But as this focus shifting was heat related i wanted to warm up the camera to 80 degrees according to the on screen temp gauge.
So under the camera now hanging on the HDMI wire in my livingroom window i put a hair dryer borrowed from my M8 ( we use that one to flash dry paint when we paint bodies for RC cars and so on.
But as it turned out that dryer must put out a almighty amount of heat cuz parts of the plastic shell and the ring still attached to the PCB melted/warped a little and the camera even did what i assume must have been a temperature safety shutdown.
But i just resat the camera by pulling the power and plugging it back in, and then not getting preoccupied by the damn computer.
So when the temperature reached 80 degrees i tweaked the focus and then put a drop of glue on the lens/mount to secure it from moving unintentionally.
So the camera got a little cool down period, after which i assembled the camera again, but due to the partly melted parts i have lost some of the horizontal click adjustment, so i had to flip the camera to the other side of my rear view mirror, and so it is now out of sight from my driving position.
And then i whent for a drive with the heater in my car at full tilt, and by doing so i was able to get the camera up to 70 degrees, well over where the focus shifted as the camera came from MEG.
And so i have grabbed 2 pictures from my drive, the first one parked at burger king the temperature was 68 degrees, and the other one are grabbed as i was close to home ( 0906 temperature unknown here )
And then off-course the same situations from my SG9665GC - V3 to use as a baseline.
