AI do you know or care if it is or not? How can you tell for sure. Like really for sure? By using AI to tell you?!!!
Test:
Review of the new VIOFO BP60 Powerbank Designed For Dashcams​
VIOFO has recently added another dedicated dashcam battery to its range, the BP60.
I have been going through the specifications, VIOFO's own information and some of the early testing already being posted here on DashCamTalk. There are quite a few things about the BP60 that caught my attention, particularly if you want parking mode without constantly drawing from the car's starter battery.
Just to make this clear from the start, I am not going to pretend these are all my own bench test results. Where I mention VIOFO's figures, they are VIOFO's published figures. Where relevant, I have also compared them with the early BP60 testing being posted by members on DashCamTalk.
What is the BP60?​
The BP60 is a 64Wh, 12.8V, 5000mAh LiFePO4 battery specifically intended for powering a dashcam in parking mode.
It measures 130 x 140 x 35 mm and weighs 0.82 kg, so it is considerably more compact than the larger BP100. The official operating temperature range is -20°C to 70°C.
Basic specifications:
  • Capacity: 64Wh
  • Rated battery: 12.8V / 5000mAh
  • Battery chemistry: LiFePO4
  • Size: 130 x 140 x 35 mm
  • Weight: 0.82 kg
  • Operating temperature: -20°C to 70°C
  • Input voltage: 11.8V to 28V
  • Bluetooth: Yes
  • Expansion battery support: No
One thing worth pointing out is the 5000mAh figure. Looking at 5000mAh alone makes this sound like an ordinary little USB power bank. It isn't. The more useful figure for comparing this type of battery is 64Wh, since this is a 12.8V LiFePO4 pack designed around dashcam use.
Charging options​
This is probably one of the most interesting things about the BP60.
There are three ways to charge it.
VIOFO quotes approximately:
  • 45 minutes using the hardwire input
  • 65 minutes using the cigarette lighter input
  • 85 minutes using USB-C
VIOFO notes that actual charging time varies with available power, temperature and operating conditions. The USB-C charging figure is based on using a suitable 60W adapter.
The USB-C input/output port is a very useful addition.
For somebody who doesn't drive very much, being able to charge the dashcam battery indoors using USB-C makes much more sense than having to drive the car purely to recharge the battery.
This was also one of the improvements highlighted in the early DashCamTalk BP60 testing. The BP60 has a USB-C input/output port rated for up to 60W PD charging, plus a separate USB-C dashcam output.
Some early testing on DashCamTalk has produced charging figures in the same general area as VIOFO's figures. One pre-production unit was reported at around 40 minutes hardwired with no load, increasing to around 60 minutes while simultaneously supplying a 6.8W load. The same testing reported approximately 65 minutes by cigarette lighter with no load and 77 minutes through 60W USB-C with no load.
Those are tester results from that particular unit rather than guaranteed retail charging times, but they are useful as an early indication.
Parking mode runtime​
VIOFO gives the following general estimates:
  • 1-channel dashcam: approximately 20 hours
  • 2-channel dashcam: approximately 16 hours
  • 3-channel dashcam: approximately 12 hours
Those are useful ballpark numbers, but I would not take them too literally.
Actual runtime depends heavily on the camera, how many channels are running and which parking mode you use.
VIOFO publishes individual figures for several cameras, and they show this quite clearly.
For example, an A229 Pro 2CH is listed at approximately 11 hours 31 minutes in low bitrate parking mode, 13 hours 26 minutes in 1fps time-lapse and 17 hours 54 minutes using its 1fps SNV mode.
Move to an A229 Pro 3CH and the estimates drop to 8 hours 31 minutes in low bitrate, 10 hours 12 minutes in normal 1fps time-lapse and 12 hours 44 minutes using 1fps SNV.
At the other end, the single-channel A119 Mini 2 is quoted at over 24 hours in low bitrate mode.
So the useful answer to "how long does the BP60 last?" is really "it depends what you connect to it."
For overnight parking, there should be plenty of useful capacity for a lot of installations. If you are expecting several days of continuous multi-channel parking recording, then 64Wh obviously isn't an enormous battery.
Proper parking mode support​
This bit is important.
The BP60 is not simply a battery with a USB socket permanently supplying 5V.
VIOFO provides two output methods that support the ACC signal required to tell a compatible dashcam that the vehicle has been switched off.
The 4-pin OUTPUT port can do this using the appropriate hardwire output cable, and the dedicated USB-C DASHCAM port can also provide the parking mode signal through VIOFO's supplied Type-C dashcam cable.
However, the normal USB-C IN/OUT port and cigarette lighter output are ordinary power outputs and do not provide the ACC signal required to trigger parking mode automatically.
That distinction is worth knowing before deciding which cable to use.
What's included?​
VIOFO has included quite a lot of installation hardware.
The official package contains:
  • BP60 battery pack
  • 3 metre hardwiring power cable
  • 2 metre cigarette lighter power cable
  • 2 metre hardwire cable adapter
  • 4 metre Type-C hardwire output cable
  • 3.5 metre dashcam Type-C power cable
  • Four types of fuse tap
  • Two Velcro strips
  • User manual
That is good to see because dedicated dashcam batteries sometimes become considerably more expensive once you start adding the cables needed for the installation you actually want.
Continued below...
Exactly my point. All a user has to do after a prompt is copy and paste this and maybe change a few specs that's it.
The amount of passive-aggressive posts referencing AI, appears to me to point to a denial of folks using AI. Seems rather obvious that they keep mentioning it - classic admission of liability.
I think to keep Dashcamtalk as a primary source, extensive AI use should be reduced or removed.
Bluetooth and the app​
The BP60 has built-in Bluetooth and connects to VIOFO's app.
The battery percentage can be checked from the phone, along with battery information and warnings. VIOFO says the app can issue a warning at 10 percent battery capacity and can also warn if the internal temperature goes above 50°C or below 0°C. Charging is paused under the temperature conditions specified by VIOFO to protect the battery.
There is also a built-in battery management system monitoring conditions including overheating, overcurrent, overcharge, over-discharge, over-voltage and short circuits.
Considering this is something potentially sitting inside a hot car for years, I would much rather have this information available than a battery pack with no communication at all.
LiFePO4 rather than a normal USB power bank​
This is also why I wouldn't compare the BP60 directly with a cheap USB power bank.
The BP60 uses LiFePO4 cells and is designed specifically around automotive use and dashcam parking operation. VIOFO specifies an operating range from -20°C to 70°C, and the battery's management system monitors its internal operating conditions.
A normal consumer power bank and a dedicated dashcam battery are trying to do two different jobs.
You are paying for considerably more than just "5000mAh".
Installation​
VIOFO suggests several possible installation locations, including under a front seat, inside the centre console or in the glovebox. Their preferred location, where space allows, is the glovebox so the pack is concealed and away from direct sunlight.
At 35 mm thick it should be fairly easy to hide compared with some of the larger dashcam batteries, although 0.82 kg means it still needs to be secured properly.
I would definitely use the supplied Velcro or another secure mounting method rather than leaving a battery of this weight loose under a seat.
BP60 versus BP100​
The choice between VIOFO's two batteries is fairly straightforward.
The BP60 is 64Wh, while the BP100 is 98Wh.
The BP60 measures 130 x 140 x 35 mm and weighs 0.82 kg. The BP100 is 171 x 171 x 35 mm and weighs 1.22 kg.
VIOFO quotes around 20 hours for a typical single-channel camera on the BP60 and around 32 hours for the BP100. The other big difference is expansion. The BP100 can use EP100 expansion batteries. The BP60 cannot.
So I don't really see the BP60 as a replacement for the BP100.
It looks more like the compact option.
If you want the longest possible parking time or expansion capability, the BP100 has the obvious advantage. If you want something smaller and USB-C charging is important to you, the BP60 starts to make more sense.
Things I like​
The main points that stand out to me are the compact size, USB-C charging, LiFePO4 chemistry, Bluetooth monitoring and the fact that the dedicated USB-C dashcam output can still support proper ignition based parking mode.
I also like that VIOFO hasn't forced everyone into a hardwired installation. You can hardwire it for the fastest charging, use the cigarette lighter socket for an easier installation, or use USB-C where appropriate.
The selection of supplied cables is also unusually complete.
Things I don't like​
The obvious limitation is capacity.
64Wh is perfectly reasonable for the size, but people running power hungry 3-channel systems should look at the camera-specific figures rather than the headline 20 hour figure.
The second limitation is the lack of expansion support. If you buy the BP60 and later decide you need substantially more parking time, you can't simply attach an EP100 to it.
There is also the price. VIOFO currently lists the BP60 at US$219.99 on its US product page. That isn't cheap compared with a normal power bank, although I don't think a normal USB power bank is really the correct comparison for the reasons above.
Final thoughts​
I think the most interesting thing about the BP60 isn't really the 5000mAh capacity.
It's the combination of 64Wh LiFePO4 construction, proper parking mode signalling, relatively fast vehicle charging, 60W USB-C charging and Bluetooth monitoring in a fairly compact package.
USB-C charging is probably the feature I would appreciate most. Not everybody drives for an hour every day. If your commute is short, being able to top the battery up indoors without special charging equipment solves a very real problem.
The capacity is the compromise. With a single-channel camera it can provide quite a lot of parking time. With a high consumption 3-channel camera, the available hours drop significantly. That isn't a fault with the BP60, it's simply what happens when 64Wh is powering several cameras simultaneously.
For normal overnight parking, the BP60 looks like a sensible size. For people wanting 24/7 coverage over several days, the larger BP100 and its expansion option are better suited to that sort of requirement.
Overall, the BP60 looks like a well thought out addition to VIOFO's battery range rather than simply a smaller BP100. The USB-C input/output arrangement and dedicated Type-C parking mode connection are particularly useful improvements.
For anyone considering one, I would work backwards from the dashcam you own and the number of hours of parking coverage you actually need. VIOFO's model-specific runtime table is much more useful than buying purely on the advertised 5000mAh figure.
Interested to see what sort of real-world runtimes other members get once more retail BP60s are in use, particularly with the A229 Pro/A329 series in 2CH and 3CH configurations.
I don't understand why you pasted your review here.
Is this supposed to be completely AI generated?
Is so what prompts did you use and what system AI?
No your point is you can make it in 5 seconds without any effort.
I'm waiting for you to teach us how this is such a simple process that is equal or better than a good reviewers work.
Of course if it is entirely AI generated it won't help anyone.
The fake AI review in POSTS #20 & #21 is pure garbage slob.
It’s all recycled word salad.
All it did was take what it “thought” was important fact / figures, and tried to fluff it up into something.
This is so stupid / counter productive.
Death to all forms of AI.
The first sentence on DCT Homepage is;
“Find the right dash cam with real community insight.”
AI is not “real community”.
The words “real community” means humans, not machines.
The second sentence on DCT Homepage is;
“Compare specs, prices and owner feedback in one dashboard built for dash cam buyers.”
AI is not “owner feedback”.
How long before someone on Reddit, YouTube, Instagram, TikTok, etc says;
“Have you heard all the reviews on DCT are written by AI”
“I say this calls for action, and now. Nip it in the bud.”
-Deputy Fife
But, like DashCamMan said;
“it would be difficult to police”
So I guess it’s impossible to enforce.
Ok I'll remove it
Why?
You never said how you created it which is relevant to this thread.
An AI checker if you can believe them suggested it only had 27% AI content.
How did you create it and what systems did you use.
This thread is to help prove a real review can be written by AI
One individual goes on about it but never shows how it can be done.
Your AI attempt appears to be cut and paste sections with human input which defeats the question.
-Deputy Fife
How did you come to that conclusion?
It reads to me as if a person wrote it. Some of the text looks like it came from Viofo's own brochures so it is not being very inventive. However we all do use the information supplied by the company as I haven't seen anyone pull their dashcams apart and make the internal public which would prove if the company really is suppling the items they say are built in.
The only thing I noticed is @mentadent used my headings from my last review. Hardly AI
If he had shown how he created this it would have helped a lot in the discussion. To remove it doesn't really prove anything.
AI comes in all forms of technology. You probable use it without even knowing. If you use amazon you will get an AI 'trying to help you' after you have pulled out all your hair you try to get to speak to a person to sort out the mess it tries to put you in.
It can be really stupid and this is what I am saying. AI can't write a 5 second review of the latest released dashcam as it doesn't have the hands on experience that only a person reviewing it would have. Its a Vibe thing AI just doesn't have.
I am waiting on 1 person who keeps insisting that AI can write a review in 5 seconds that he should be able to post but he can't as the AI engines at this point in time that are free don't have the smarts. EVen it they are not free I doubt that can know what we do from a first touch point of the products.
But it would be great to see him prove me wrong and we can all learn from it.
@LateralNW It was all AI.
I used deepseek/deepseek-v4.1-flash, and web search tool calls.
I defined an Agent with inputs:
{ 'product-name', 'review-title', 'post-length', 'source-urls' }
And a single output.
Prompt:
Write a forum-style review about subject {product-name} with a title {review-title}
Use web-tool to access {source-urls}
Requirements:
  • Write it like a typical detailed review post from the forum provided. Intentionally ingest other reviews for style and structure.
  • Research the subject properly using the supplied sources.
  • Make no factual mistakes.
  • Do not invent personal testing or experience.
  • Keep the writing natural, conversational, enthustiastic, and useful.
  • Cover the important specifications, features, strengths, weaknesses and practical considerations.
  • Use headings and bullet points where useful, in the style of existing forum posts.
  • Do not use em dashes.
  • Maximum 9,999 characters per forum posts to fit forum requirements.
  • If the review is too long, split it into multiple posts such as "Post 1 of 2" and "Post 2 of 2".
  • Keep each post safely below the 9,999-character limit.
  • Finish in a natural forum style that encourages discussion.
Return only the finished forum post or posts.
I'll post the output next as requested, for 'Review of the new VIOFO BP60 Powerbank Designed For Dashcams', https://dashcamtalk.com/forum and https://www.viofo.com/products/viofo-bp60-5000mah-dash-cam-battery-pack-for-parking-mode
What is the BP60?​
  • Capacity: 64Wh
  • Weight: 0.82 kg
  • Bluetooth: Yes
Charging options​
What's included?​
  • BP60 battery pack
  • Two Velcro strips
  • User manual
Continued below...
Installation​
BP60 versus BP100​
Things I like​
Final thoughts​
References:
VIOFO BP60 product page:
DashCamTalk forum:
https://dashcamtalk.com/forum/#dash-cam-forum.1
DashCamTalk BP60 testing discussion:
https://dashcamtalk.com/forum/threads/viofo-bp60-dash-cam-battery-pack-test-review-pp.61734/
Installation​
BP60 versus BP100​
Things I like​
Final thoughts​
References:
DashCamTalk forum:
Ok to be honest I am confused.
This reads really good to me.
It seems to have all the touch points. Note that I don't have this unit in my possession.
The requirement you put on the AI and the AI you used was written by someone who knows how to get things out of an AI engine.
I'm guessing you used an AI to help with the prompts or you know how to write a long prompt like that.
It seemed personalised with what seemed like insight into the product.
It does lack some techincal facts when I would usually be adding testing to the product.
It also doesn't have any photos that are taken by you. I guess that is what seperates the real reviews.
So while it might be able to do text what happened to the photos and technical tests that usually go with a review.
I don't see this as slop writing but as I have said before I don't have degrees and masters in English language.
I don't see it as a complete review and needs supporting images etc.
Thanks for supplying the how to and what was used. It will be interesting if others can get similar results.
Because I’m a reasonable person of average intelligence.
It basically plagiarized what I wrote in my BP60 & BP100 testing threads.
I’m the only person that uses a 6.8 Watt load for charging / discharging tests.
I think that might be the core issue of this entire AI debate.
I think you may have a reading comprehension disorder.
This is not an attack your intelligence.
I’m saying it’s possible you just read things differently.
We ain’t producing creative writing for leisure reading.
Our reviews serve as “reference material”.
What are manufacturer specifications?
Does it perform to specifications?
What does it do?
What doesn’t it do?
What’s improved from last years model?
How does it compare to it’s closest competitors?
What are Pros & Cons & Final Thoughts?
What’s missing?
What needs improvement?
Would you buy this with your own cash money?
Would you recommend this to friends & family?
Is this E-Waste?
What’s it like using it for 1-3-6 Months, (observe & report)?
Explain things so a 10 year old could understand.
This ain’t rocket science.
None of this requires any use of AI.
Death to all forms of AI 🤖🤖🤖☠️☠️☠️
You're welcome.
I wrote the prompt and tooling myself. It's not very advanced. I don't have a masters in English, but I do have one in Computer Science.
Three pictures:
Two videos:
Yeah that's my point. It has to steal the information it can't create stuff we discover first. Until it's published.
That's why I'd like to see Dashcamtalk stay top of the slop pyramid by only allowing accurate facts.
The **70mai 4K Omni X800** is a direct evolution of 70mai’s original 360° rotating dash cam platform (the X200). While the original model proved the utility of a motorized pan-and-tilt design, it was held back by a 1080p resolution and built-in non-expandable storage. The X800 fixes those major pain points by upgrading to a **4K Sony STARVIS 2 sensor**, adding **microSD support**, using a **supercapacitor**, and introducing an optional **1080p rear camera**.
### Technical Specifications
| Feature | Specification |
| **Front Camera Sensor** | Sony STARVIS 2 IMX678 (4K UHD: $3840 \times 2160$) |
| **Front Frame Rate** | Up to 60 FPS (4K single-channel) / 30 FPS (dual-channel mode) |
| **Front FOV & Aperture** | 146° Field of View, f/1.7 aperture, HDR support |
| **Rear Camera (Optional)** | Sony STARVIS 2 IMX662 (1080p FHD @ 30 FPS) |
| **Rotation Mechanism** | Motorized 360° horizontal pan with AI motion tracking |
| **Power Source** | Built-in Supercapacitor (operational temp: -40°C to 85°C) |
| **Storage** | External MicroSD slot supporting up to 512GB (U3 / V30 required) |
| **Display** | 1.4-inch IPS Screen |
| **Connectivity** | Wi-Fi 6 (2.4GHz & 5GHz), Bluetooth 5.3, GPS |
| **Optional Connectivity** | 4G LTE Cellular Module (enables remote live-view & cloud notifications) |
### Core Performance & Highlights
#### 1. Excellent 4K Front Video Quality
The jump to the Sony STARVIS 2 IMX678 sensor yields significantly improved image clarity over 1080p generation models. License plates are legible at city and highway speeds during the day. HDR handles harsh contrasts, glare, and night recording well, balancing headlight reflection off metallic plates far better than average standard-range dash cams.
#### 2. Truly Functional 360° Rotation
Unlike multi-lens cabin setups that are permanently fixed, the X800 uses a quiet step motor. In parking mode, AI human detection turns the lens to follow someone approaching your car. You can also control the camera via voice commands ("Capture left/right") or swipe through the 70mai smartphone app to pan the camera into the cabin or toward a side window.
#### 3. Smart Cloud Features (Via Optional 4G Kit)
With the optional 4G hardwire kit installed, the X800 sends instant push notifications to your phone when an impact or suspicious movement occurs. You can remotely launch a live view, stream video, and pan the lens in real time to survey your vehicle's surroundings.
#### 4. Hardware Reliability Upgrades
Moving to a **supercapacitor** instead of a lithium-ion battery vastly improves thermal stability. It tolerates freezing conditions and hot windshields without swelling or shutting down. The switch to expandable **microSD storage (up to 512GB)** resolves the quick card-fill issues associated with large 4K video files.
### Potential Drawbacks & Limitations
* **Mounting Jitter on Rough Roads:** The tall, cylindrical housing and rotatable stem design can cause minor physical vibration/shaking on unpaved or poorly maintained roads, which slightly degrades fine details like license plates when driving over bumps.
* **Mediocre 1080p Rear Camera:** While the front camera records in native 4K, the rear camera is capped at 1080p. Images towards the outer edges of the rear lens can blur, and night performance is significantly lower than the main unit.
* **Large File Sizes & High Storage Demands:** Writing simultaneous 4K front and 1080p rear clips eats up roughly 300–350MB per minute of driving. High-end V30/U3 microSD cards are essential to prevent buffer bottlenecks.
* **Blind Spot During Rotation:** If the camera rotates to track a pedestrian at the side window while you are parked, it temporarily stops recording directly in front of the vehicle. Dedicated multi-channel systems (front/rear/sides) keep static coverage everywhere at once, whereas the Omni rotates a single front lens.
* **Paywalled Features:** Getting the most out of the unit requires optional add-ons. Hardwired parking modes require the standard 70mai Hardwire Kit, while live cloud access and GPS tracking alerts require the separate 4G LTE kit.
* **No IR Lights for Cabin Recording at Night:** While you can tell the camera to point inward at passengers, it lacks infrared (IR) LEDs. Nighttime cabin footage will be dark unless there is ambient street lighting.
### Verdict
The 70mai 4K Omni X800 fixes nearly every design complaint of its predecessor. If you want a hybrid device that acts as a **sharp 4K road-recorder while driving** and a **smart 360° security camera while parked**, it is one of the most versatile dash cams in its price bracket. However, if you regularly drive on rough unpaved roads or prefer dedicated static multi-lens setups for total continuous perimeter coverage, traditional dual- or triple-channel cameras (like a VIOFO or BlackVue) may suit your needs better.
The only prompt I entered in Gemini was: write me a review on said product, covering it's specifications and potential drawbacks.
Even if a product has not even been reviewed yet, my point to others here is that AI takes a lot of the work out of having to write specifications for example and some other advertising points for the dashcam.
Some minor edits to correct facts or formatting would be required, but most of the work would have been done in seconds by AI.
The reason the last text by @mentadent only had 27% for AI is that he set the parameters of what DeepSeek should set. For those that don't, the AI checker is much higher at example 84% for that 70mai 4K Omni review quoted above. With the other 16% changed by the end user.
