jwr1221
Hi all! First post to ask for some help with my SG9665SC. It seems like I'm having the same issue as others where it powers up, records for a few seconds then screen goes blank and it re-boots. It worked flawlessly for probably close to 4 years and just recently started this behavior. It was purchased from Pier28 back in 2016 sometime but I don't have any of the original paperwork to know when for sure. In the brief time it stays on and is recording, the screen flickers if that means anything...
Anyway, at first I thought it may have been the power adapter so I tried a different one of similar style (12VDC power port adapter to USB mini) with same results. So then I tried a different USB cable powered by a hard-wired 12VDC to USB converter. Same issue. Tried re-formatting the original 64Gb Transcend card and then tried a different 64Gb card and still had the same issue. I then updated the firmware to the latest ver 7 (SG20191111.V4) from the streetguardian website and still have the same issue.
Any other suggestions to try or is it just time to replace it?
Thanks for any suggestions you can offer!
Josh
Houston TX
Josh
Houston TX
