I did the test this morning and the result is inconclusive. It's not something a "normal consumer" can accurately test out. I had my car running for half an hour from 8:00am to 8:30am (without moving) and parked it under a tree. By 10:30am. the dashcam is already turned off. I checked the HK3 and the red LED is "dimmed". I think a power cut off has occurred. The multimeter reading at that time is 12.9V. I believe when it turned off, it should be around 12.8V. The configured cut-off voltage is 12.2V though. So, letting the engine running for half an hour is insufficient to charge the battery for testing. Btw, the temperature inside the car was 33°C at 11:30am and around 39°C at 12:00pm. I used a digital thermometer placed on the dashboard.
I did a little more tests on the HK3.
- The red LED will light up whenever it has input power. However it will be dimmed, until the ACC line has power or the BAT line input is more than 13V. This will make the red LED "bright".
- If the ACC line received power but the voltage is less than 13V, the HK3 will provide power to the dashcam, but after around 1 to 2 minutes of losing power from ACC line, it will cut off power to the dashcam and the red LED will be dimmed.
- If the ACC line received power with voltage more than 13V, then the HK3 will behave "normally" when ACC line stopped recieving power.
The above observation means that, if you want to test the parking mode properly, you need to start the engine before turning it off and let the dashcam enter parking mode. I believe only
@viofo is able to provide us more details on HK3 behaviour.
I also noted that even with 12.2V as the cut off voltage set, my HK3 cut off power to the dashcam whenever the voltage reading from the fuse to the BAT is ~12.8V.
Is my HK3 faulty or not working as it should?
The following are the results of my previous tests (HK3 cut off power set to 12.0V).
- With resolution set to 1080p, 1440p and 4K, at night (after driving home from work), it is able to record in parking mode from 8:30pm to 7:30am. It's still on when I enter the car.
- With resolution set to 1080p, at day time (after driving to work), it is able to record in parking mode from 9:00am to 7:30pm. It's still on when I enter the car.
- With resolution set to 1440p and 4K, at day time, it always turn off at around 10:30am to 1:30pm. Most of the time, it turned off at around 11:00am.
Again, as a "normal consumer", most of us don't actually have the time to actually perform a "professional" testing on the dashcam (and HK3) as the car battery need to be fully charged first before starting the tests. I can only do so when I drive to work. However, when I am at work, I couldn't be sitting in the car monitoring the voltage, the temperature and the dashcam, right? Also after work at 7:30pm, it would be too dark for me to open up the compartment to reach the fuse box and the HK3. Additionally, whenever I start my car engine, the voltage reading will go beyond 13V and after turning it off immediately, it stays above 13V for more than 5 minutes (it decreases very very very slow).
Attached at photos of my set-up. The HK3 red LED taken is when it is in "dimmed" mode. For the ground, I piggy-back on the existing ground cable. I think it's the GPS module of my car navigator.
