Are there any known issue about 3-Wire Hardwiring Kit ?
TheGhost31
Haute-Garonne
France
Hi
I decided to connect the dashcam with the hardwire kit today !
And everything works well during the tests. OK great !
I decided to hide some cables and do some "cable management" to avoid a mistake or bad electic contact.
I closed all protections about my car ect. ready to go on the road and...... surprise the dashcam doesn't not working anymore >< !!!!
I opened again my car protections to investigate and I noticed a really bad electic contact somewhere but I could not find it ... I touched with my fingers cables and "magic happens", it works again, I wanted to move them again from 2 cms (yellow and red cables) and I got some shutdowns and restarts of the dashcam ...
I tried again to touch them and nothing badhappens (so everything works), then I tried again and the dashcam shutdown happens. I needed to shake everything and the dashcam works again !
So two questions, is it only me ?
I will try to have the cables sticked / blocked somewhere ! Event with the road and bumps ect, that will not be easy ...
Or that could explains some behaviors with users using this Kit ?!
( Some users, said something like "my dashcam reboots or doesn't switch between state as expected one time by week, sometimes more sometimes less") ?
I tried to let some space between yellow and red cables because (it's a supposition) but when these cables are too close / together, a lot of reboots or shutdowns of the camera happens :(
Now that's seems to be more stable (by magic).
I will let you know with the time
Regards
CaptureYourAction
Retailer
New England
DOD, Dome Technologies, VicoVation, Viofo, GitUp
Bad connection somewhere. Make sure you have a good ground.
T
TheGhost31
Haute-Garonne
France
I will check again (I already did it) but it's blocked between metal and a bolt
So I don't think it's problem of ground, otherwise it's will never work ;)
It's look like mlore as a cable broken inside ?Or even on the separation of the 3 cables (black / red / yellow) with the little part black in plastic
If it's happens again, I will need to investigate but I prefered to ask before, if it was a known issue ;)
niko
Retailer
Dublin
Ireland
Is it happens when you touch car fuse side add-a-circuits plugs or the hardwiring side "bullet-type" plugs?
CaptureYourAction
Retailer
New England
Check the crimp on the ground connection. I've had one break under the black shrink tubing at the crimp connector.
T
TheGhost31
Haute-Garonne
France
Not sure to undertsand this part "or the hardwiring side "bullet-type" plugs?" sorry my english is limited ...
but for sure, it's not the following case "touch car fuse side add-a-circuits plugs", I already tried it and nothing change (so it's OK).
I tried the main black (not ground) cable (before the black plastic with 3 cables (yellow, red , black) and nothing so it's OK.
But from the black plastic part and the (yellow / red cable) something happens ;)
Mhh again not sure to understand the word 'crimp', is it something like 'to connect electric wires between them via a metallic piece of joint?'
In this case, I didn't do it because Viofo sold it with already a metal piece (semicircle) at the end of the ground cable and I just tightened really hard on the bolt to be sure it's linked :)
When you said "I've had one break under the black shrink tubing at the crimp connector."
Maybe a picture with an arrow to show me the location of the problem could help me :)
niko
Retailer
Dublin
Ireland
Yeah, the photo with the pointing arrow will help to understand.
Sent from my VKY-L29 using Tapatalk
T
TheGhost31
Haute-Garonne
France
I can't open them :(. I got the following message.
Oops! We ran into some problems.
The requested page could not be found.
Edit:
Now it's loading by magic too! :)
So forgot my message
Thanks for the photo, today I checked again the fusibles and cables (yellow / red). I taped the wires to avoid movements from them with bumps and holes in the road ect
I unscrewed and re-screwed and cleaned the bolt to have a good ground in the aim to be sure it's correctly connected.
Now (for the moment), everything works well, if something wrong again, I will check in first the black piece where you put an arrow to mentioned it :)
