wkearney99
- May 21, 2017
- Bethesda, MD USA
- ARECORD B40D
I've got a B40D on the windshield and rear window of my Porsche Cayenne GTS. It works pretty reliably. It's nothing special but OK for my interests most of the time.
This past Saturday I had it in the car when running an autocross. Most of the time it worked as expected. When driving up to the start and around the lot it worked fine. During the first run it also worked fine. But during subsequent runs the .MOV file it recorded won't play. Videos before and after it are fine. Just ones right from the start are 'defective'.
I tried playing from both files copied to a local hard drive and from the card directly (via a USB3 reader).
Anyone else seen this kind of problem? Like I wrote, it records just fine during the drives around the lot and up to the start. But the runs where I nailed it off the starting line won't play.
The card used for the recording is a Samsung 64GB Evo (orange label). It was full when I pulled it out of the dashcam. It lives in the car all the time, and has been reliably recycling old files when it runs out of space.
I wouldn't normally expect to use this for autocross. But the 3M picture hanging strip held it onto the glass just fine, that and I'd forgotten it was in there. (You normally remove EVERYTHING from the interior). That and I hadn't brought along my GoPro 4 or any of it's mounts.
Any tools out there I should try to use for fixing them or extracting at least part of the videos?
