jamesbcd said:Do you not have a multimeter to double check what fuse to use?
jamesbcd said:A cheap one will do the job, you'll only be needing to check if there is any power so either a cheap multimeter or one of those circuit tester screwdriver type things (not sure what the name is).
Sweguy said:Dont you have a schematic over the fuses on the coverbox?
