B1M Does Not Work with Solid Red Light
airdrawndagger13
Jakarta
Indonesia
I installed Blueskysea B1M on my motorcycle.
At first I tested with the supply USB cable. It worked well. All the 4 green lights and 1 red light turned on.
I tried to connect with the motorcycle battery (connected to power cable, it also worked well).
But, after I installed all the cameras, cables into the motorcycle, plugged the DVR unit, connected to the power supply, it didn't work. Only the right light is on for about 10 seconds.
I've tried:
1. Connected again with the USB cable.
2. I tried to update the version with the empty 8Gb and 32Gb microSD card, still it doesn't work.
(the .bin file was gone after I put into the DVR, is that mean the unit has been updated?)
3. Changed and plugged from front to back camera and vice versa.
Kindly need your advice @estore009
Thank you.
Best to take a short video to show it the problem; I need to know if this DVR box can reboot or not after powering on! Thank you!
Here's the video that shows the unit turning on with only the red light after powering:
Thanks! It indicates that this DVR Box cannot reboot!
It only happens when the fornt camera was faulty; So possible a faulty camera part or a faulty extention cable;
1, Swap front camera with the rear camera to see if it can reboot or not?
2, Give it a try again without the extention cable or check all camera connectors!
I've tried to swap front to rear camera. But it didn't work.
I'll try again without the extension cable.
Hope within this week can do it. Thank you.
1. Swap front camera with the rear camera to see if it can reboot or not?
- Already tried, but it didn't work
2. Give it a try again without the extention cable or check all camera connectors!
Ok, DM your order details for the warranty, thanks!
