hi, I have a problem with the b1w.
until a few days ago, with the 614s firmware, I had the parking mode and pressing the button manually, the wifi turned off. always. every time I turned on the car the cam started recording but the wifi remained off.
now instead every time I turn on the car, the wifi is activated (light turns green) even if then afterwards I manually turn off the wifi (red light) after the next start of the car it returns active. Also every time I turn on the car and the cam starts, there is the little voice that tells me that the micro sd has been detected and that the recording starts (before that it didn't happen to me).
I did a test. I formatted the sd, put the 614s firmware back, and connected the cam to a samsung charger. At home the behavior of the dashcam is perfect, as in the past in the car.
I put the cam back in the car, and the problem came back, when the engine started the cam started with active wifi.
