Hi All,
Lets talk about Li-ion Batteries, and Li-Polymer Batteries.
I'm looking at getting a new cam - and I have noticed some come with a "super capacitor" instead of a battery.
Lets take the Mini 0803 as that would be good for me as progression from my 0801's. In the context of Motion detection.....................
There is a thread here
http://dashcamtalk.com/forum/threads/what-about-motion-detection.6134/
In it Jokiin says a)
"if you want to use parking mode the camera should not use an internal battery"
He also says b)
"also requires being powered constantly to work which is not good given the internal battery"
He also says c)
"powering it all the time isn't advisable though as it has a built in battery"
He also says d)
"will constantly be getting charged and topped up, in warm weather that's a big problem, best case scenario is short battery life, worst case it swells up and ends up catching fire"
He also says e)
"Not Li-ion, worse, Li-po"
Now - please correct me if I am wrong here - as I am not technical when it comes to electricals.
The camera is powered via a cigarette socket when driving - it is actually designed SPECIFICALLY to run off such a socket - and will not record for long on the internal battery alone as it will quickly go flat.
In points b) c) d) e) above - he is saying DONT use power all the time as it is basically dangerous.
Infact - its worse with these because they have a Li-Po battery.
So I am confused - why design a car camera which uses an internal Li-Po battery, is CONSTANTLY getting charged up (well it is in the 0801 anyway) on and off with general driving use.
So is there a difference between the way the battery is charged up under different usage conditions?
a) Motion Detect - Jokiin says - quite clearly - "DONT USE IT WITH POWER FROM THE CAR".
b) Normal Drive Recording - its ok to use it with power from the car.
Whats the score here - it would seem to me that BOTH modes of use are the same in terms of what happens with the battery in the camera - so why are they BOTH NOT dangerous, and ONLY motion detect is dangerous?
See what I mean?
2.
He also says b)
He also says c)
He also says d)
He also says e)
See what I mean?
2.
