Bitrate issue
zefs
Greece
Hello, I recently got a Yi and using Yimax script along with 4gb clip size and 35mbps bitrate firmware.
I've noticed that some of the clips have low bitrate (21mbps) which I think has to do with battery life?
The clip that had the lower bitrate was recorded at a point where the button ring was red so I suppose it has to do with that, can anyone confirm that or have found any solution to this?
nCaine
Poland
Probable your card is too slow to handle 35mbits. It will split the file and drop the bitrate to lower level so the recording can cotinue.
What card you have ??
zefs
zefs
Greece
I have a sandisk ultra class 10 32gb
punish1985
Taiwan, Province Of China
i think it's a mysterious bug....
i tried several microsd cards already..with writing speed of 18MB, 45MB, and even up to 90 MB...still turn out to be the same thing...
So, unless you are using a fake card or only C4 card, i don't really think the bitrate issue has anything to do with memory cards..
even when you don't use the 35mb script or custom firmware..just stick to the stock firmware with 1080p 60fps
the bitrate won't stay at around 25mb, either...the bitrates of the following files might be only 22mb or 18mb
my model is 23L....but not everyone with this model reports the issue here.
Tanckom
Germany
I have the same problem. Got a sandisk 10 card, bought from amazon.de via the official reseller, and 2k, 1080(in all fps, tried all scripts) are not working with 35MBPs... Can somebody help?
punish1985
so far...i haven't see any solution to this issue...
You can try to use stock firmware...without any script, and set the resolution to 1080 60fps....and test if the bitrate stays stable of 25mb per second...
for me, i can get only 22mb of bitrate using the stock firmware...
