blackview ambarella a12 speed ,date STAMP settings
@dariod I thought I had a link, but only have the zip file. It's about 11-12mb. Send me a private message with your email if you want me to send it to you.
Does this cam have MpH or it it only KpH?
Cool, Thanks for the update.
firmware works, but seems to long to get gps fix, I only drive like 15 minutes to work, but even after that time speed still zero, weird. my other mini cameras pick up gps fix in couple minutes.
player 1.119v works fine. thanks for that.
off topic: tried update my mini 0803 (firmware dated 2013) but when sd card inserted with firmware, its not promting to update, just start to recording instead of promt for firmware update, any ideas ? should i start another tread about this ?
(my other mini 0805 updated successfully)
thanks guys in advance.
Shouldn't take 15 minutes. I'd move the gps module to another spot and see if that helps.
I think gps unit was not pluged in properly.... my fault :(
Yes, properly connecting the module should definitely help.
