Blackvue 500 wifi issues :(
e30blitz
So my new vue 500 arrived
This morning
Tried to connect the wifi but to no avail
Reinstalling the app does not work
Does any one have any ideas
M-Element
did you changed to a different password?
If so, maybe you can try reset it back to "blackvue" see if it work.
E
e30blitz
No go
Still no luck
Hillbilly
Sunshine Coast
DR750s x2 DR450 x2
e30blitz said:
No go
Still no luck
Have you got WIFI turned on in the settings on the Camera
jazzyone
By chance are you connected to the BV with another device while trying to connect with your iPhone, perhaps a tablet or a different phone?
The camera can only connect to one device at a time.
If not how strong and how stable is the BV wifi signal strength? You should have full, consistent signal strength at close distance. If your wifi signal is weak/unstable, you could have a problem with the Wifi-module on the camera and need a replacement.
Finally, you need to use the default password. If you changed the password through the iPhone APP, the password will not work.
EDIT: Actually, looking at your screen capture, it looks like you changed the default password to something else. You entered 13 characters. You probably changed the default password using the iPhone APP. In order to change the default password, you need to do it in the desktop application, not the iphone application. Changing the wifi password on the iPhone application will cause connection problems.
E
e30blitz
So this is what I have done so far ,
Sealed box
Opened and plugged into lighter socket
Downloaded iphone 5 app
In settings looked for blkvue
Enter password default at first I thought it was this
Plus the 6 numbers from the side of the box
No luck
Even on the app it cannot connect
Proberly because of wrong password error or something
Then after prompting by other members I read the book again ;)
And found this :)
Great I thought
So I ended my home wifi
Reset my phone again
And reset the camera again by pushing the reset button
I thought ok let's try settings again
Found it on here
And then entered the default password
Blackvue
Yes yes sir
Even has the new wifi symbol on the phone see. ,
Ok then I went back to the app and tried to click on the center button
Which says wifi
And
I guess. I should be at square one but I can't be because I am connected in the settings to the camera ,
Wifi
But the app does not find it
Huh :(
So now having my bowl of cereal at 1030pm
Because the sugar will kick in I think
I am no further
Thanks for the help
Please help :)
E
e30blitz
Sealed box
No luck
And found this :)
Great I thought
Found it on here
Blackvue
Yes yes sir
Which says wifi
And
Wifi
Huh :(
I am no further
Thanks for the help
Please help :)
E
e30blitz
Success
For some unknown to the human race reason
The app found the camera
Yes
Thanks members for your all your help
I was fed going back and forth to the van
I went down to the electronics store
And picked this up and plugged the camera in the kitchen :)
Now on with the recording :)
E
e30blitz
E
e30blitz
Haha
So true that's my work van
Dashboard is a mess
I guess before I drop the kids off to football should really clear it up ;)
BukVieng
RI
I have the same issue. But this was after I updated to the new Blackvue App. Previos iPhone App version I was able to login and view my files. Now it is doing the same as you. It is connected to the Blackvue because you can still see the Live feed and the settings...but no access to the files. I am also looking for an answer...
V
E
e30blitz
V
I was going to update the blackvue
On the
Mac
But with past experience from other software updates on Mac
Running issues. Always worried me
I have held off on that update just in case there is any bugs
How about going back to the old version
I have not connected my blackvue to the Mac yet
I have saved the files on the phone
But not gone that step further
E
e30blitz
V
On the
Mac
Scott Taylor
I have a DR650GW-2CH & iPhone 5.
For the record, I was having the same issue, not being able to connect my iPhone to the Blackvue using WiFi. I did a bit of a Google search and ended up here. This is how I fixed it:
Firstly, I was setting up the BlackVue in my garage which was within distance of my home WiFi. I thought that this was interfering so I moved the car out of distance of my home network. This didn't work. I disconnected my iPhone from my home network, this didn't work.
Upon re-reading the instructions (http://blackvueshop.co.uk/support/manuals/) I found that you could reformat the card whilst it was inserted in the BlackVue. To do this you have to hold down the WiFi button for 10 seconds. After ten seconds the BlackVue makes a noise. Release your finger from the button and the BlackVue formats the card for about 20-30 seconds then commences normal operation. I then went to the settings in my iPhone to connect to WiFi (settings > WiFi), selected the BlackVue WiFi network and entered the password 'blackvue' (all lower case). I then went to the BlackVue App on my phone and selected 'BlackVue Wi-Fi'. Success!
Note (from my experience so far) that if you want to connect you phone with the WiFi you must turn on the WiFi on the BlackVue every time the camera has shut down. I also had to connect to the BlackVue WiFi, on my iPhone, every time.
Also, a reset via the software on your computer doesn't work.
Hope this helps.
Similar threads
