BlackVue Announces Flagship Cloud-Compatible Dashcam Successor DR750S Series
Maria@Pittasoft
Likes
2
Korea, Republic Of
#1
BlackVue, dashboard camera manufacturer based in South Korea, has just released a successor to its best-selling DR650S Series connected dashcam. The DR750S Series packs dual Sony STARVIS Full HD sensors and significant performance improvement as well as compatibility with BlackVue Over the Cloud. The DR750S-2CH and DR750S-1CH are now available for preorder.
BLACKVUE DR750S-2CH
DUAL-FULL HD CLOUD DASHCAM
DASHCAM WITHOUT COMPROMISE
Dual STARVIS™ sensors in Full HD 1080p (front 60 / rear 30 frames per second).
Seeking a dual-camera system that does not compromise on fidelity?
Look no further.
Record fluid videos of the front and back of your car at a wide 139° view angle.
STARVIS imaging sensors are a reference in video clarity under low light, and they equip both the front and rear cameras of the DR750S-2CH. You can rest assured that your dashcam will capture critical details whether you are driving or letting your BlackVue monitor your parked vehicle.
With the free Over the Cloud add-on service, check on your car from anywhere, anytime.
BUILT-IN IMPACT & MOTION DETECTION
MARK IMPORTANT FILES AND ENABLE PARKING MODE
While driving, your BlackVue detects impacts and sudden changes in speed. While parked, it also detects movements*.
Videos files are marked accordingly so that you can easily find the relevant ones in the BlackVue Viewer for Windows and Mac OS or the BlackVue App for Android and iOS.
(*) For Parking Mode recording, an external battery pack (Power Magic Battery Pack) or a hardwiring kit (Power Magic Pro) is required.
OPTIMIZED FILE MANAGEMENT
Event Files Overwrite Protection:
Dashcams record in a loop, overwriting older files when the memory is full. BlackVue DR750S-2CH can prevent Event files (triggered manually or by impacts) overwriting. Up to fifty (50) files can be protected this way. You can choose to allow new Event files to overwrite past Event files, thus keeping the latest fifty.
Adaptive Format-Free File Management
Developed by BlackVue, this file system improves recording stability and reduces the need for microSD card formatting, while giving you the flexibility to change recording time unit (1/2/3 minutes) and quality settings. Still, the videos saved are playable on most viewers.
Scheduled Reboots
HIGH FRAME RATE FOR EXTRA FLUIDITY
THE ADVANTAGE OF 60FPS VIDEO CAPTURE
The front-facing camera records extra fluid videos at 60 frames per second, keeping all details sharp even in fast action. With 60fps, motion blur is much reduced compared to 30fps. That means your BlackVue can better capture details–like license plates–even in fast-moving objects.
Note 1: the higher the image quality setting, the higher the bitrate and the bigger the file size. A bigger size will increase the time necessary to transfer a video file over Wi-Fi.
Note 2: Remote Live View using BlackVue Over the Cloud is not affected by the image quality and framerate settings.
Specifications:
Camera -
Front: STARVIS™ CMOS Sensor (Approx. 2.1 M Pixel)
Rear: STARVIS™ CMOS Sensor (Approx. 2.1 M Pixel)
Viewing Angle -
Front: Diagonal 139°, Horizontal 116°, Vertical 61°
Rear: Diagonal 139°, Horizontal 116°, Vertical 61°
Resolution/Frame Rate - <Front – Rear>
Full HD (1920×1080) @60fps – Full HD (1920×1080) @30fps (Sports)
Full HD (1920×1080) @30fps – Full HD (1920×1080) @30fps
Full HD (1920×1080) @30fps – HD (1280×720) @30fps
HD (1280×720) @30fps – HD (1280×720) @30fps
*Frame rate may vary during Wi-Fi streaming.
Wi-Fi - Built-in
GPS - Built-in
Others -
Adaptive Format-Free File Management System
Cloud Compatible
FOR MORE INFORMATION ON THE BLACKVUE DR750S SERIES GO TO WWW.BLACKVUE.COM.
Similar threads
