Blackvue B124X discharges quickly
Dacug
Europe
Germany
My Blackvue isn't used in a car yet. It basically sits on my desk to test a multi-camera / Raspberry Pi setup.
Charging:
I charged it with a cigarette lighter -> power plug adapter at a power point in my home.
--> Works fine, the app shows 100% charge level
Use:
Works fine, it can power a dashcam and a Raspberry Pi at the same time, power consumption is at a normal level
Discharge:
Now comes the strange part. If the B124X is turned off and just sits on the desk, then the charge level goes down from 60% to 10% within a week.
Is it normal that LiFePo batteries discharge that quickly when they are not used? An unused power bank would need months to go down from 60% to 10%.
Tomcat
Netherlands
Netherlands
No its not normal. B124x should hold charge if not used. I think these lose more power then some lithium ion based cells over time. But it also charges alot faster and is more durable much more cycles. there is some loss but not as much as you describe. I have a Cellink neo here not used for a week and it was still nearly full.
If you have a blackvue dashcam and use this alone from 100% to 0% a couple of times i could tell you if it lives upto its promises.
https://blackvue-nederland.nl/voedingsmodules/blackvue-power-magic-ultra-battery-b-
ModelGemiddeld stroomverbruik (Wh) bij constante opnameGemiddelde gebruiksduur B124
DR900S-1CH3,4821 uur 53 minuten
DR900S-2CH4,5616 uur 42 minuten
DR750S-1CH3,3622 uur 40 minuten
DR750S-2CH4,3217 uur 38 minuten
DR590W-1CH2,5230 uur 14 minuten
DR590W-2Ch3,621 uur 10 minuten
DR590-1CH2,431 uur en 45 minuten
DR590-2CH3,4821 uur 53 minuten
Note that these are not the exact times you will get but they give a good indication of what it should be able to do.
a DR750s 2ch running at extreme + wifi might still get around 20 hours
while my DR900s extreme+wifi may only get 15 hours orso. the DR900s consumes quite a bit more power then a DR750s in parking mode.
