Peter Wilson
- Oct 11, 2013
- Newcastle upon Tyne
- United Kingdom
- Mini 0801 DashCam and Blackvue DR550GW, iPhone 4S.
Hi forum Buds.
This is my Config.ini file. so far i have checked the bits in red and have a description. hope this helps.
Has anyone got any information on the black bits.
I have tryed changing the storage setting but noticed the Kib Changed and the video quality made no difference apart from the blackvue player plays the front video slow and jumpy when its set lower and the rear camera plays real fast. they play correctly in media player but jump a little in VLC.
[Tab1]
TimeZone=317 (The Time zone your in)
ImageSetting=0 (0=FHD-HD, 1=FHD-HD 15fps, 2=HD-HD 30fps, 3=HD-HD 15fps)
Brightness=2 (0=Darkest 4=Brightest)
NormalRecord=0 (0=On 1=Off) (Record Setting in config)
VoiceRecord=0 (0=On 1=Off) (Voice Record Setting in config)
DateDisplay=0(0=On 1=Off) (Time Stamp Setting in config)
SpeedUnit=1 (0=kmph 1=mph 2=off)
NormalRecordTime=1 (1,2,3 Minutes)
EventRecordTime=1 (1,2,3 Minutes)
StorageSetting=0 (I have had a mess with this on 1 2 and 3 no difference) Anyone know?
StorageRate=0 (I have had a mess with this upto 17 as per dr500gw it made 42 Kib instead of 20)
AutoParking=0 (0=on 1=off)
FileFormat=0 (Have not messed with this) would like to try later think it may change from mpeg4 to avi)
VideoQuality=2 (Have had this on 0,1,2,3,4,5) Made no difference
PROFILETYPE=1 (No Idea havent changed) Anyone know?
[Tab2]
NORMALSENSOR1=0 (set to 0 on mine thats 1G Still triggers on potholes and speed bumps)
NORMALSENSOR2=0 (set to 0 on mine thats 1G Still triggers on potholes and speed bumps)
NORMALSENSOR3=0 (set to 0 on mine thats 1G Still triggers on potholes and speed bumps)
PARKINGSENSOR1=80 (set to 75-80 on mine thats low Still takes ages to go into park mode)
PARKINGSENSOR2=80 (set to 75-80 on mine thats low Still takes ages to go into park mode)
PARKINGSENSOR3=80 (set to 75-80 on mine thats low Still takes ages to go into park mode)
MOTIONSENSOR=1 (1=On 0=Off)
[Tab3]
LED1=1 (1=On 0=Off GPS LED)
LED2=0 (1=On 0=Off Record LED)
NORMALCOLOR=7 (Changes the color of the front LED)
PARKINGCOLOR=7 (Changes the color of the front LED)
STARTVOICE=0 (Turning on Voice 0=Off 1=On)
NORMALSTARTVOICE=1 (Recording on Voice 0=Off 1=On)
EVENTSTARTVOICE=1 (Beep when Gforce recorded Voice 0=Off 1=On)
CHANGERECORDMODEVOICE=1 (Change of mode Wifi sound etc On and Off Voice 0=Off 1=On)
PARKINGMODEVOICE=1 (Says Parking mode Disabled 1=On 0=Off)
ENDVOICE=1 (Turning off Voice 0=Off 1=On)
VOLUME=71 (Volume of Voice 100=Full 0=Off)
AVOUT=0 (I have not tested this but "assume" the camera has a hidden output inside for testing)
[Wifi]
ap_ssid=
ap_pw=5181178AEB83EDE2230DA62AF55B537EFA6F18A66443E4A545A2DCB5AFB4756D
onstart=0
web_id=blackvue
web_pw=5181178AEB83EDE2230DA62AF55B537EFA6F18A66443E4A545A2DCB5AFB4756D
wifimode=AP
sta_ssid=
sta_pw=5181178AEB83EDE2230DA62AF55B537EFA6F18A66443E4A545A2DCB5AFB4756D
[Tab1]
[Tab2]
[Tab3]
[Wifi]
ap_ssid=
onstart=0
web_id=blackvue
wifimode=AP
sta_ssid=
