- Apr 14, 2013
- Minsk
- Belarus
- Street Guardian, BlackVue, Thinkware
DR600GW-HD_v1.003ENG(2015.01.23)_Windows.zip
DR600GW-HD_v1.003RUS(2015.01.23)_Windows.zip
DR600GW-HD_v1.003ENG(2015.01.23)_Mac.zip
DR600GW-HD_v1.003RUS(2015.01.23)_Mac.zip
1. FOTA Upgrade support
1) Functional Description
FOTA(Firmware-Over-The-Air) is literally the function that allows the firmware upgrade over the Wi-Fi.
Your firmware upgrade through FOTA function on BlackVue App will be easier and more convenient than using PC.
2) How to use
a. Please press the [Firmware Download] button after running the BlackVue App on the smartphone with internet access enabled.
b. Please select the model name and the language and press [OK].
c. Firmware information will be appeared on the smartphone, firmware download will be proceeded as you press [OK].
d. Please connect your smartphone with BlackVue unit through Wi-Fi when the firmware download is completed.
e. [Firmware Upgrade] menu will be appeared when you click “Setting” on the upper menu on BlackVue App.
* [Firmware Upgrade] menu only appears when the firmware upgrade is necessary on the phone.
f. Please transfer upgraded firmware to the BlackVue unit by running [Firmware Upgrade] menu.
g. BlackVue App will be disconnected and the BlackVue unit will be re-booted as the firmware transfer is completed.
h. The recording voice of “BlackVue will be upgraded” will be spoken after 3 minutes of standby(the firmware-unzipping time),
and the BlackVue’s starting voice(“Blackvue for your safe driving, starting normal recording”) will be spoken after the upgrade is completed
and the unit is fully re-booted.
3) Notes
a. FOTA upgrade will be available after firmware 2.004 version is installed on the BlackVue unit.
b. Please do not turn off the power until the system is fully rebooted itself, since FOTA upgrade takes about 6 minutes.
2. Reduced audio recording noise
2) How to use
3) Notes
