Blackvue DR650s problem with video quality
The brightness is too high and you need to point the camera lower Optimum is 1/3 sky at the top rest road and bonnet.
It is however fairly fuzzy
Will try to set it correctly and see if it helped.
Seems heat related, you can test by leaving it off for a while and seeing if the videos on initial startup look sharper
My problem only occurs in warm weather. Is the camcorder eligible for warranty replacement?
I have the same situation as the DR650GW when it overheats. The problem in the 650s was to be resolved but probably not quite succeeded...
From what I have observed the sharpness of the image changes with a lot of sunshine. The camera stops sharpening the road and focuses on the dashboard. In the case of overcast days there is no problem with sharpness.
