Hello everyone, I'm at my wits end with this issue, I'm having an issue with my celllink Neo. I have it hard wired to charge (without PMP) when I start up my car and the app is telling me its going to take 1 minute to charge to full from completely dead. It goes to 100% within a few minutes and then when i shut the car off it only provides power to my dash camera for maybe 15 minutes, then cuts off (battery becomes completely dead, I can't even connect to it with the app). I've had this battery since Jan 2018 and have never had this problem.... I've even changed the fuse its connected to and same issue. Is there a solution for this?
Something wrong with the battery? First attached picture is with the car just turned on for a few minutes and the second picture is approx 5 minutes after.
Edit: car off, NEO at 100%. If I toggle the input switch in the back to "OFF", battery shuts off and my cameras shut off as well. Toggling back on to "HIGH" or "LOW" turns the NEO on and cameras on. Input, if the battery is at 100%, should not affect the output of the NEO nor the power of the NEO, since it should be 100% charged.
