Crixus said:
Only 2 hours on a single charge
Hello again,
Just opened up the box to look at the battery for the DVR. It's a KB-01 Li-on 3.7v 900mAh battery. After a bit of a quick Google quest I've discovered that it's the same as the Sony Ericsson BST40 battery. After a little bit more digging I found this battery
http://www.yoobao.com/en/product.asp?b_ ... 3&a_id=381 which is 1800mAh and it should theoretically give around 4 hours life to the DVR. The only downside is that it has twice the thickness of the original battery but will still fit, just without the battery cover in place. I have no idea of the cost or availability of this battery, there may even be other alternatives, as my search was pretty quick.
Another option is that the DVR uses a standard USB connector for charging. You could just use a portable battery pack to run it off.
Just putting it all out there for you.
