Broken G1W-C
CD55
Manteca,CA
I had removed my G1W-C so I could clean the rear window.
After mounting the camera back on the rear window I plugged in the cable and the connecter seemed to go further then normal.
I took the camera off and after opening I saw the power-in connector had popped off the board.
Should I just throw it away or could this be saved?
logicgamer
Netherlands
Could be fixed rather easy with a soldering iron. Reattach the old connector if possible, connect a new one (quite cheap) or even better, a short cable with the connector on the end.
If you have never used a soldering iron before i recommend looking for someone who has.
CD55
CD55
Manteca,CA
I guess it will get chucked then.
Time to get a new rearview...
