Buffering / Low Framerate on recording wifi
Hi,
2 issues:
1. When I first installed everything, watching the clips over wifi was not interrupted. Now, it will play 2-3sec then buffer unless I skip the progress bar along and press play again. Any fixes?
2. I noticed that if I am transferring a clip - the recording which is taking place while the clip is transferring will not be recorded at a high frame rate. I'm guessing it's because the device is processing the transfer and having to record, and juggling both is causing it to faulter... Any fixes?
BlackboxMyCar
Retailer
Vancouver, BC
Thinkware, BlackVue, IROAD, Viofo, BlackSys
I find it streams a bit quicker when the card is freshly formatted, perhaps give that a try to see if it changes the WiFI speed?
When you're downloading a clip, it shouldn't affect the existing clip's frame rate but it's possible that your existing clip is in parking mode which may be 15FPS depending on your firmware version.
