- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
Are you looking for an excellent high quality, stealthy set it and forget it automatic loop recording water resistant remote wire "dashcam" for your Motorcycle? (or any other vehicle need) Look no further here it is
I'd like to announce the all new BULLETHD BIKER MATE and BIKER PRO products that are available starting today exclusively from the global team effort of @Pier28 @niko & @CalgaryDashCam
http://www.bullethd.us
Flyer FRONT:
Flyer BACK:
BIKER PRO WiFi
BIKER MATE (same specs as the PRO, only no WiFi)
If you don't need or want WiFi you can save some bucks getting the basic model.
______________________________________________________
USER MANUALS
Latest Firmware:
http://www.bullethd.us/#!-firmwares/cndf
BULLETHD - BIKER PRO App Demonstration
BULLETHD | BIKER PRO VS GOPRO | Video Quality Test - Day-time
BULLETHD | BIKER PRO VS GOPRO | Video Quality Test - NIGHT TEST
BIKER PRO VS GoPro Hero4 - vibration test on Harley Davidson Forty-Eight
BIKER PRO - 5 minutes installation on Harley Davidson Forty Eight.
(Note, Installing main DVR unit inside your saddle bags, or under the seat compartment is probably best)
RAW examples:
(more coming soon)
The following were captured on a friends small honda bike, and the mount wasn't very tight so pay no attention to the vibrations.
Prius incident (front camera)
https://www.dropbox.com/s/s5q8n3hgveu0vf5/Prius.MOV?dl=1
Prius incident (2nd rear camera)
https://www.dropbox.com/s/xom8g6h4riex3ph/Prius-Rear.MOV?dl=1
Random Full Clip:
https://www.dropbox.com/s/8zdmorth21ed8yh/EVE00403.MOV?dl=1
Settings.txt File Example:
Bitrate is above 16Mbps
BULLETHD BIKER PRO vs INNOVV C1/C2/C3
Where buy:
USA/Canada:
@Pier28
Canada:
@CalgaryDashCam
Europe:
(from our favorite Forum power user @niko)
Flyer FRONT:
Flyer BACK:
BIKER PRO WiFi
- BIKER PRO has a great water-resistant design which allows recording video even in heavy rain without a worry. (perfect for permanent installations) Hide the main DVR controller unit under your seat or stick it anywhere you'd like. Are you looking for the perfect high quality, stealthy set it and forget it automatic loop recording "dashcam" for your motorcycle? Look no further this is it.
- Built-in Wi-Fi Module, Free iOS & Android app (search app/play store for "BULLETHD BIKER PRO"), 1920x1080, 30fps, Full HD, H.264 MOV, f/1.8 Lens Aperture, 6 Element Glass, Anti Scratch + Dual Anti-Reflection, 18mm Ultra-Wide 160 Degree Wide Angle Lens, Novatek 96655 and Aptina AR0330, Storage up to 64GB microSD (microSD memory card not included)
- Image Noise Reduction, Date & Time Stamp, Engine Start Recording, G-Sensor, Stabilizer, Good low-light Performance. 5/10/15 Looping Recording Segments (next firmware will have shorter segment choices)
- Built-in 850mAh 1 hour+ Battery (for supplemental usage), Optic nerve cable is durable. The cable has an outer packet that is waterproof, oil abrasion-resistant and erosion resistant. For more information see bullethd.us
- Main DVR Controller + Flat Mount + 3M VHB Adhesive Type-A + 78 inch (2M) Optic Nerve Cable + Streamlined Lens Module + 360 Degree Lens Flat Mount + 3M VHB Adhesive Type-B, + Dual USB Power Converter (DC 12V to DC 5V) + mini USB cable + 2 piece Cable Connector. Cables are tapered and snugly fit into the ports.
- Compatible with any GoPro mount!
- The normal power usage for the Biker PRO/MATE is 500mAh. The max power usage is 550mAh
Free Smart Phone App:
(don't be confused by the 2 other BULLET HD apps you'll see)
iOS: https://itunes.apple.com/app/id992038639
Android: https://play.google.com/store/apps/details?id=hk.com.silvercreation.bikerpro
USER MANUALS
Latest Firmware:
RAW examples:
(more coming soon)
Random Full Clip:
Code:
#system setting
VERSION = BP2015041704 # can't change
WIFI_NAME = BIKER-PRO # wifi name,length 1-32 (a-z, A-Z, 0-9)
WIFI_PASSWORD = 00000000 # wifi password, length 8-32 (a-z, A-Z, 0-9)
RESOLUTICON = 0 # (0=1080p, 1= 720p@60pfs)
VIDEO_TIME = 0 # (0=5mins, 1=10mins, 2=15mins) recording chunk time
QUALITY = 0 # (0=fine, 1=good, 2=normal)
LOOP_RECORD = 1 # (0=off, 1=on)
DATE_STAMP = 1 # (0=off, 1=on)
G-SENSOR = 3 # (0=high, 1=mid,2=low,3=off)
TIMELAPSE = 0 # (0=off, 1=1s,2=2s,3=5s,3=10s,4=30s,5=60s)
AUDIO_RECORD = 1 # (0=off, 1=on)
AUTO_POWER_OFF = 1 # 0=Off, 1=3min,2=5min,3=10min
TIME_SET = N2015.01.01.00:00:00 # Y=change N=not change
DEFAULT_SETTING = 0 # (0=false, 1=true) when set to 1, the camera will ignore other settings, set to system default and write the default settings in this file
CAMERA_NAME = PIER28 # Device ID
#end
Where buy:
USA/Canada:
@Pier28
Canada:
@CalgaryDashCam
Europe:
