HELP, just set up my camera system and it tested okay. Took it out for a test run and nothing. The red lights come on give one long beep, 6 or 7 short beeps and shuts off. Any ideas????
Hi Wayne I just responded to your contact us email but got some EarthLink spam protection response I couldn't get past so not sure you received my response.
that behavior condition is most likely one of the following reasons.
1) Firmware settings are in an unstable condition.
In the settings.txt file change
DEFAULT_SETTING = 0
to
DEFAULT_SETTING = 1
Re-insert card, power on, and it will flush out the system. Try running it in the default state without changing anything but wifi name for several days
2) You could have a intermittent HDMI video cable. We can send anther one. (this usually fixes the stuck solid red eyes)
3) Your power supply could be intermittently under powered. We've replaced the power supply in the past to fix similar behaviors. if you have an external USB power bank you can bypass your power supply and test with that. Also you should have 1 camera per power supply. We are finding that using one power supply to power two units is not stable. (Don't charge a phone on the second USB port for example.
4) running any of the wires too close to spark plug wires can cause instability. Customers rerouted wires to the other side of the bike with success.
5) using red/grey SanDisk cards are not supported. Transcend is best. 32GB is the most stable.
What firmware version are you running? Latest one increased stability. If you just bought it, will already have the latest though.
