BULLETHD BIKER PRO - Problems
Okay, lights off, plugged into a house plug with output 5.0v 1000mA
red lights came on blinked three or four times with three beeps and shut off
The red lights blink followed by three beeps, it does this four times and shuts off. Small red power light on top is on. What do I try next?
I switched the default setting to "1" and reinserted card before trying the usb power on the trike. Using the same memory card I started with
Should I go and get a different memory card b4 trying anything else? Even though this one was recording when the camera ran?
Do you see a red LED power light at the top of the alien head?
Well even if you end up getting a replacement, you shouldn't use the SanDisk card so maybe try not using the Sandisk card first and we'll go from there.
Yes, the red LED power light is on,
The Sandisk is the only one I have at the moment except for a 64GB no name and it would not format to fat32 says exFat or ntfs?
I'm not the most computer literate person on the block either....
PNY is good
Get transcend 32GB from Amazon if possible.
No experience with Sony cards.
33GB will not need special formatting. 64GB will need special formatting
Which one? I'll order from Amazon and wait til it get here to try again....
