Camera not starting
boag
I've noticed that maybe one time out of ten when I start the car the camera does not come on. Typically happens when I am making multiple stops while doing errands. I unplug the unit and replug and it works fine.
Has anyone else experienced this with their camera?
kevin666
Shenzhen
China
mini 0906/0806/0806S/0903/0905
when this situation, camera can turn on by pressing power button instead of replug the unit?
B
boag
no I haven't tried this since I typically don't catch it till I'm moving. It's easier for me to reach the plug than the unit.
B
boag
it happened again today and I pulled over and pressed the on button and it came on. So yes it can be restarted by the off/on button.
kevin666
Shenzhen
China
This show that camera is ok, did you use hardwire kit?
mini0906 used super capacitor, so it will worked several seconds after cut down power. if ignited when camera did not fully turned off, camera will not recieve signal to turn on.
B
boag
no it's not using the hardwire connection. It's the std cigarette plug.
B
boag
also I switch it between cars(and it happens in both cars) so it's probably not the 12 outlet.
kvn4
having same problem and is happeneing more frequently. id like to know if camera is about to go deadand its not that old.
B
boag
leaving a gas station last night and almost got hit. Looked at the unit and it was blank, I hit the on switch and it came on - ergo it didn't work when I needed it.
B
boag
it appears from the comment above that the camera has issues when being shut down, interperting the comment I believe it is a hardware issue in that the system does not allow full shutdown.
kvn4
im using the hard wire kit and it is installed correctly. thats my problem .what i do every time i get in and start my car i check the cameras lights thats how i know its not turning on.using the cigarette lighter will turn power off when you turn off car and when you start it, it should get power then.some lighter sockets only work with the ignition on. hope this helps
B
boag
I'm starting to think that it's due to short duration stops. From what Kevin said above the capacitor doesn't completely discharge so there's an issue with it restarting. Just a hunch though.
Similar threads
