Camera turns off after 10 mins
DarrenHealy
Fife
Nextbase 322GW
I start my car the camera starts up fine but after roughly 10 mins it turns off but the blue light stays solid . Am I doing something wrong ?
Camera is powered by a usb output on my stereo . I'd wire it constant live but i'm not convinced this is a good idea ?
EGS
Texas
Viofo A129 Pro Duo, A129 Plus (eMMC), A119S x 2, Zenfox T3
maybe the screens saver is on? Have you checked your footage to see if the camera continued recording after the screen shut off? You can connect it temporarily to a constant source with its own usb adapter ands see if it still shuts off after 10 or 15 minutes. it could be that the port on your stereo is not strong enough to supply the camera entirely. if it works ok that way then you can see about doing a hard wire kit properly installed
DarrenHealy
DarrenHealy
Fife
Nextbase 322GW
The screensaver comes on quite quickly , showing my speed if i touch the screen it shows the camera recording but after approx 10 mins it goes off completely but the blue light is on
EGS
Texas
It would be good to try using the cigarette lighter usb adapter and see what happens.
DarrenHealy
DarrenHealy
Fife
Nextbase 322GW
Sensible way to proceed i think . Thanks i appreciate your help . I'll let you know tomorrow how it goes
EGS
Texas
I'm sorry I can't be of better help.
DarrenHealy
DarrenHealy
Fife
Nextbase 322GW
Yours may well be the solution , if so I need to hard wire but tricky finding a path through the bulkhead . Constant live would be easy but I'm unsure if that is a good idea
Kremmen
West London & Reading
      Viofo A119 V2 Viofo A119 V3
Bulkhead ?
Have you not got an under dash fusebox.
Also, permanent hardwire isn't a good idea as the cam will be recording 24x7 and you'll get overheating and you'll get through SDcards like there's no tomorrow.
My recommendation has always been to try and find a fuse that is only active with ignition position 2. That makes the cam startup just that little bit later and reduces the 'starter motor effect'
DarrenHealy
DarrenHealy
Fife
Nextbase 322GW
Bulkhead ?
Theres a fusebox beautifully placed at the end of the dash but it contains only constant live fuses , the other fuse box (the one with radio , cig lighter fuses) is under the bonnet and threading the wire through would be very tricky i reckon .
Kremmen
That's unusual to not have a variety of fuses 'indoors'.
What car is this ?
M8TJT
East Sussex
2x750 2CH
You two are early birds aren't you?
Could you not wire it to the back of the ciggy lighter?
Kremmen
I'm always early.
From what I've managed to find Mercedes interior fuses aren't permanent power but they take a long time to power down giving the impression they are permanent.
I've also found posts saying that the fuse cover is very difficult to get off so be careful.
DarrenHealy
DarrenHealy
Fife
Nextbase 322GW
I'm always early.
Need to check that out , cover is dead easy just prises off
DarrenHealy
DarrenHealy
Fife
Nextbase 322GW
Tried it with ciggy lighter but the bloody thing doesnt stay in grrrrrr , going to need to be the under bonnet fuse box at some point i think
NextBase Support
Caerphilly
Nextbase
Hi Darren,
Sorry to join the party a bit late.
Unfortunately the output from your stereo is insufficient to power the Dash Cam. The normal use case for a USB socket on a stereo is to read memory sticks (which take a few mA), where as the Dash Cam draws approximately 1.2A with dual cameras and battery charging. We do supply a cigarette lighter power cable with every Dash Cam, however I can read that you've had issues with the connection in your cigarette lighter socket. We also supply Hard Wire kits through various Outlets, and we'd recommend hard wiring the Dash Cam into your fuse box within the cabin (on the permanent live) in this situation, however turning on Parking Mode so that the camera switches off when no movement is detected. It also has a Battery Protection Cut Out, which prevents the car's battery from being drained to a level where it would not start.
Thanks once again to Kremmen and M8TJT for their brilliant advice in this thread.
Regards,
Millie- Nextbase
DarrenHealy
DarrenHealy
Fife
Nextbase 322GW
Hi Darren,
Regards,
Millie- Nextbase
Hi
Appreciate your reply , bought a new lighter socket thing and just driven 3 hours to Newcastle and it's been fine .
I have the hardwire kit which I'll sort when I have chance .
Appreciate all the replies on my question
NextBase Support
Caerphilly
Nextbase
Darren,
Glad to hear you've got yourself up and running. Anything we can do to help, you know where I am.
Millie- Nextbase
Paul Iddon
Preston
A129 Pro Duo 4K, A129+ Duo, A139, A119 V3, NB 522GW
Millie - where is Tiffany?
K 322GW 1
S 322GW 9
H 322GW 4
5 322GW 11
LeonC1963 322GW 1
