ctrl_interface=/var/run/wpa_supplicant
network={
ssid="ThompsonAC1A50"
key_mgmt=WPA-PSK
proto=WPA2 WPA
pairwise=CCMP TKIP
psk="TypeHerePasswordYouUseToConnectToYourWifi"
What is your SSID, security mode, if WPA then what algorithm?
Then the default wifi.conf should work (as it covers both wpa&wpa2, tkip&aes)
Make sure your password and SSID are in double quotes, that you used notepad++ / pspad for editing (because of newlines) and that you didn't change anything else except lines SSID and PSK
Well, FINALLY it worked for me - but only using WPA-Personal/AES
- it did NOT work using WPA2-Personal/AES! Maybe you jagger also have
to switch your router to WPA-Personal/AES, as above.
PS. I use Win7 64bit and now everything works as expected, even CC.exe,
streaming view on VLC etc.
i have wpa2-personal(PSK) with AES and cams are working as they should.
Be aware, that they are VERY sensitive to signal strength & quality.
unless you want to set static IP, you don't need to change anything else.
K | Yi Action Camera wifi help | Yi Action Camera | 0 | |
D | Bootup Wifi When Camera is Turned On | Yi Action Camera | 0 | |
N | Xiaoyi camera wifi signal problem | Yi Action Camera | 0 | |
N | Xiaomi Yi Action Camera Wifi problem | Yi Action Camera | 2 | |
Xiaomi Yi Sports Camera (1080p 60fps, WiFi) review | Yi Action Camera | 0 |
