Andy_S
- May 5, 2015
- Czech Republic
- Download
Enable start_wifi_while_booted in cameraNot needed, but wifi LED will be off.
- Unpack on your SD card
- modify wpa_supplicant.conf for your network
- turn on camera and wait for 1s beep
Tested on 1.2.13, 1.2.0 and 1.0.12 - should work on other firmware versions as well (dunno, didn't test).
Does not do any permanent changes!
When you remove these files from your SD card, you get your camera back to original.
I added a simple watchdog.sh script that is launched AS LAST COMMAND IN autoexec.sh
Even if you want to use some more tweaks, this line must be the last - following lines will not be executed.
Just uncomment it in autoexec.ash and modify in wifi/watchdog.sh and it will monitor camera's wifi & reconnect when needed.
Known "bug" - when camera loses wifi signal (for ANY reason), it does not reconnect, you need to restart camera.
If you like my work, consider donating some spare change
