Can I use my older models GPS with the SG9663DCPRO?
iDash
I have a much older street guardian with a GPS unit still on my dash. It uses the same connector. Can I use this old GPS unit or should I replace it with the new one?
kamkar1
Denmark
10 years, many dashcams
Use the old GPS antenna and keep the new one as spare, they do have a battery inside and they can go wonky, though mine have all been very strong aside for the GCX2 which was bad from the factory so i just out a GC antenna on it to not bother the guys with little matters.
kamkar1
Denmark
Yes they have a small battery too.
I asume this is one reason we talk about Cold fix and Hot fix when the car have just been stopped a little while.
Street Guardian USA
Retailer
Oakland Park, Florida (USA)
StreetGuardian.CAM Amazon.com
DashCamOnBoard
How long will the battery last and what kind of battery is it? Can it be replaced when it dies out?
Street Guardian USA
Retailer
It’s a Very tiny button battery soldered to GPS PCB. Would be easier to replace the GPS in the future. I can’t even remember the last time I saw one go bad but possible I guess. We have plenty of spare GPS in stock too. (2 year warranty as well)
DashCamOnBoard
Understood, how about the dash cam itself. Does it also have a little battery?
Street Guardian USA
Retailer
Yes all dashcams have a very tiny RTC (Real Time Clock) rechargeable button battery soldered to the PCB that holds the date and time between powering the camera. GPS automatically sets the date and time as well.
kamkar1
Denmark
I can recall one guy having a faulty GPS, but unsure if that too was the battery in it.
And then one of the SG cameras i got to test also took a long time to get a fix, pointing at a bad battery it it, i just replaced it with a old GPS as it was not the first SG camera donated to me.
Both the GPS battery and the one inside the cameras, you are better off not messing with those, at least not without having the means to acquire a new camera anyway.
Same advise as with overclocking computers ASO, if you can not handle breaking it dont mess with it, which was very much true in the old days as it often required you to solder additional components to expensive PC hardware.
These small batteries are 1/3 - 1/4 of your average CR 3032 button cell you see in TV remotes ASO.
S SG9663DC & SG9663DCPRO 7
