Try as I might, I can't change any resolution settings via AutoExec. I can easily get it to connect to wifi using the script, but nothing I do has any effect on the resolution using a range of example scripts on this forum.
I can do some things like set the camera to take RAW images and set the bitrate, but just cannot change the video resolution.
I've tried various versions and hacked versions of the firmware, to no avail.
There is something going on with my cameras that possibly relate to this other issue I was having https://dashcamtalk.com/forum/threads/solved-record-video-in-station-mode-crashes-camera.15444
If I try and change the mode with the app to video it crashes the app, if I try and record video when in photo mode via the app it crashes the camera.
Seems like there's some kind of security settings that stop the overriding of camera settings via AutoExec or Telnet maybe?
Anyone any ideas?
Here is an example I'm trying to use at the moment
Anyone any ideas?
Code:
sleep 5
lu_util exec telnetd -l/bin/sh
#disable thumbnail file
lu_util exec rm /tmp/fuse_d/DCIM/100MEDIA/*_thm.mp4
sleep 1
#set file size to 4GB
writew 0xC03A8520 0x2004
sleep 3
# Set Video Resolution 1600x1200 60/50P 4:3
writew 0xC05C2092 0x420C
sleep 1
# Set RAW + JPG Photo
t app test debug_dump 14
sleep 5
t pwm 1 enable
sleep .5
t pwm 1 disable
lu_util exec '/tmp/fuse_d/wifi/sta.sh'
t pwm 1 enable
sleep 1
t pwm 1 disable
