Can't update firmware
Chris29
Romania
So, I just bought a white xiaomi yi. I want to update to 1.0.9 version using this method.
I did all steps however when I start the camera (with update file on root of the card etc) nothing is happening. It's just starting normally. I'm using a 32 gb class 10 card.
What am I doing wrong?
Evgeniy
Russian Federation
Firmware file on root filename is firmware.bin? If you connect USB-cable to PC do not do this. Is wrong for update.
jokiin
Too many ¯\_(ツ)_/¯
do you have filename extensions turned on in your computer, if you don't it's easy to end up with a file named firmware.bin.bin which won't run
C
Chris29
Romania
This is how it looks.
jokiin
Too many ¯\_(ツ)_/¯
go to control panel/folder options, make sure hide extensions for known file types is unchecked
Assuming that's correct just make sure the card is empty (format first is probably best) and copy the firmware file only to the card and try again, use a 32gb card or smaller
C
Chris29
Romania
Ok. Thanks. I did that. Now I'm charging the camera full and I will try. I will be back with my result.
C
Chris29
Romania
if that was checked just make sure your firmware is correctly named firmware.bin
Now is correctly named firmware.bin. The camera is now fully charged. Just one question before to proceed. Do I need to connect the camera with usb cable to a power source(PC) or just start it and let her flash without any power source.
sp5it
ko02oi
Poland
Xiaomi YI
Do not connect camera to PC during firmware update. It was already written.
Mike
C
Chris29
Romania
Mike
Where is written?
I see on step 4 that is recommended to connect the camera to a power source:
I'm confused now. :confused:
rockman18
France
You can plug the camera to a power source like a phone charger (it's not mandatory, honnestly I don't plug it when I update mine but mine is fully charged), but don't connect it to a PC cause the camera will turn to usb storage mode for the computer.
During the update wait until the camera turn off alone.
C
Chris29
Romania
So I managed to make the update (without putting YI to a power source) and everything was ok. :)
Now I have another problem with android app. Actually I had the same problem before updating the camera but I was hoping to be resolved with 1.0.9.
So, my android app can't connect to YI camera. I'm doing every step. Starting the camera, wifi activated(blue led blinks) and trying to connect. I get that "chose a camera Wifi Connection", the camera is listed as YDXJ_2818196. It goes until the step where I need to put the password (1...0).
It loading with "connecting to camera" for like a minute or so and I get every time "failed to connect".
I tried with lots of app versions. The original one from xiaomi qr code link. 1.3 and 1.4 as well as 1.3 and 1.4 from the english translated apps.
Nothing works. :(
Is might me a problem with my phone? It's a Newman N2 (chinese phone from pandawill) with Android 4.1.1
Anyone has the same problem?
PS: I can connect to the camera with an Iphone via 3rd party apps but those are having big lag. Also I would like to connect with the official app.
rockman18
France
I have a OnePlus One. Before, I had no problem to connect to my Yi using WiFi, but since the last update (last week) to Android Lollipop, I have to restart my phone before using the app because I can connect in WiFi only once after I have to reset my phone. I think there is a bug in Wifi implementation of the protocol.
Can you try something. Go to Android Settings -> Wifi and connect directly your phone to the Yi Cam. Does it work ?
C
Chris29
Romania
I restarted my phone and connected directly to Yi cam from android settings wifi. It says it connected. But is useless. I mean I need to go to the app and connect via that red camera button placed in the lower part of the app. And it still can't connect from there.
Evgeniy
Russian Federation
Delete wi-fi settings for camera ap and connect to camera from mobile app.
Roma
Indonesia
why after I upgraded the firmware suddenly can not live again, only 3 small light turns red, please help
