Cellink B v2 connections
Petrol Head
Does cellink B v2 have ACC pass through.
The Cellink input connects to an ignitionised fuse and an earth
The Cellink output has 3 wires 1 ACC, 1 BAT, 1 GROUND
So can I hardwire the 3 wires of the F770 directly the 3 wires of the Cellink output or should I connect the F770 ACC wire to another ignitionised fuse so its ignition supply is separate from the Cellink.
jokiin
Too many ¯\_(ツ)_/¯
If it has 3 wire output then it sounds like they've updated it like the Neo, you would connect directly to that, don't bypass it
