Ok well here's the deal. I reinstalled firmware with the wifi app. I couldn't figure out how to do it otherwise. No change after that. I checked both cards config files and they were still as I wanted them. So in a desperate move, I borrowed a co-workers Android phone thinking Koreans must like Androids and not so much iPhones. I installed the app and it worked beautifully. Pretty funny though listening to her talk Korean
Thanks again for the help Robert!! Not sure what they are thinking over there
Here's what I got from them.
블루투스 관련
모든 전자기기에 전파가 발생하고 그러한 기기들끼리 상호간섭이 생길 수 있듯이
마찬가지로 하나의 핸드폰에서 블루투스와 함께 사용할 시 블랙박스 와이파이 수신환경에도 영향이 있을 수 밖에 없습니다.
It is generated and propagated to all electronic devices, as this can cause interference among these devices
As inevitably it is affected even when the black box receives Wi-Fi and Bluetooth in a single environment for use with mobile phones.
앱 관련
1) When I tap the Lukas SD icon, it points to the "Lukas" folder on the card, which is empty.
사용자가 클릭한Lukas SD icon에서는 ‘사용자가 직접 Download하여 핸드폰 내부 메모리로 저장이 된 영상만’이 보여집니다.
사용자가 따로 저장한 영상이 없으면 물론 그 공간은 empty가 됩니다.
The user clicks Lukas SD icon ' Download user only the image directly to a cell phone is stored in the internal memory, is shown.
If the video that you have stored separately as well as the space will be empty.
2) "Lukas" and it switches to "SD" and displays all of the files.
두번째로 누른 Lukas에서는 ‘현재 블랙박스 메모리카드에 저장되어져있는 영상’들이 나열이 됩니다.
즉 앱 메인 화면에서 Lukas Connection을 누르는것과 같은 기능 입니다.
The second click will list Lukas ' image that been stored in the memory card is currently black box ' are .
That is the same function as pressing Lukas Connection from the main app screen
