Clean windows.
Paul Iddon
Preston
A129 Pro Duo 4K, A129+ Duo, A119 V3, NB 522GW & 622GW
What do all you guys do to keep the interior glass of your windscreen clear - mine is noticeable really at night (daytime seems ok) and seems to often (always) have a haze around the street lights.
Untitled.pngDo you use anything in particular?
DT MI
Michigan
More than my wife thinks I need.
My process is to first scrub them with terrycloth and plain water then follow that up with InvisibleGlass. Works really well.
Paul Iddon
Paul Iddon
Preston
I tried that product, plus 2 Autoglym products. Neither seem to last more than a couple of days at best - I reckon my old leaky tub screws up any cleaning...
DT MI
Michigan
Neither seem to last more than a couple of days at best...
I would think that once the glass is clean it should stay that way for some time (unless you smoke in the car). Is there something in the vehicle that could be outgassing?... or maybe something in your environment causing a film to develop on the glass?
Paul Iddon
Paul Iddon
Preston
I don't smoke (nor does anyone else that might use my car - there's only 3 of us.
The aircon doesn't work and is never used anyway - and there's nothing else that can create a gas except the wife and daughters farts... :LOL:
I get moisture inside from somewhere - until recently there was an issue with water getting in through the pollen filter and trickling into the footwell but I have fixed that, so I cant think what else it could be.
3 days ago I used Autoglym and now 3 nights later the haze is back....
I'm going to try a coouple of different products this week to see if anything changes the outcome for longer after use.
DT MI
Michigan
It doesn't sound like it's the products you're using but rather something environmental causing the film to redeposit on the glass. I would suspect the moisture you mention as a (probable?) cause.
Dashmellow
Uncanny Valley (●_●)
Umpteen
I've tried both Autoglym and Invisible Glass. Both are excellent and really quite similar. Autoglym takes a bit more elbow grease. Recently, I've found myself favoring Invisible Glass for its slightly longer lasting effect and easier application.
My vehicle is parked outside under a huge 240 year old maple tree and I often have a difficult problem with persistent water spots on the exterior of the windshield that are very hard to remove. The best technique I've come up with is to clean with a standard foaming glass cleaner, then thoroughly scrub the glass with #0000 steel wool and finally give it a good cleaning with Autoglym or Invisible Glass. It's the only thing that's really worked. Terrycloth or other sturdy cotton, lint free fabric and Invisible Glass or Autoglym seems to work best on my interior glass. The whole endeavor lasts a reasonable amount of time before it needs some attention again. (several weeks)
Paul Iddon
Paul Iddon
Preston
I have some Invisble Glass, and Autoglym's Fast Glass. I have used both and tbh, I can't remember if one did better or not.
Tomorrow, I will wash the glass with washing up liquid and white vinegar, and then I am going to try an e-cloth that should be coming from Amazon.
Hopefully, I will get a finish that lasts a week!
Dashmellow
Umpteen
In my experience, perhaps because of my environment, it doesn't pay to clean the interior glass without also cleaning the exterior at the same time.
For the exterior I've become a big fan of the #0000 steel wool technique. Works remarkably well. Worth trying!
I don't bother with RainX type products anymore like in the video. I have better luck just keeping the glass clean.
Dashmellow
Umpteen
not sure if they have this over in UK or not..
the aerosol is what you want
spray on microfiber, wipe on glass, turn microfiber to dry side, wipe off, no streaks
I mentioned earlier that I start my cleaning process by using a foaming glass cleaner and that happens to be the same product I use. It's pretty good stuff but alone on windshield exteriors it doesn't quite do what the additional treatment with #0000 steel wool plus Autoglym or Invisible Glass can accomplish though, if you have a serious water spot and splattered bug problem.
SawMaster
SC
G1W-S, G1W-HC, G1W clone, B1W, K2S, B2W, (ex N2Pro & Mobius)
@Paul Iddon Before you clean, take a scent-free paper towel or cloth, and rub it hard on the windshield where the defroster vent hits it. Have the most sensitive nose on the household give it a sniff and sere if it smells like your car's antifreeze. Even a tiny slow occasional drop of a leak on the heater core will make your windows seem like they're smeared with nicotine or vaseline, and no normal glass cleaner will get it off. Ammonia and vinegar don't cut it either. I've recently heard that cleaning with a grease-cutting soap (like your washing-up liquid) is supposed to work for this although you may have to wash and dry several times to get it all off. It's supposed to work equally well for nicotine.
The glass cleaner @dr_ramoray speaks of is what my windshield installer used, but they didn't do a good job with it when they put my windshield in a couple weeks ago. Even though my glass is brand new it has something greasy on it right out of the wrapper and I'm going to give it a go in a day or two. I'll post the results here about how well the washing-up liquid works for me, and I'll be finishing up with the aerosol "Invisible Glass" which I normally use.
Dashmellow
Umpteen
If it's a grease cutter that's required I can highly recommend Citra Solv. Fantastic natural product and one of the very best grease cutting and general purpose cleaning liquids I know of.
https://www.amazon.com/gp/B0012BVXSO
Check out some of the Amazon reviews.
kamkar
Denmark
10 years, many dashcams
That remind me i have some de greaser on spray, smell very much citrus.
I have sort of the same problem, no matter how often i clean the inside of my windscreen it dont seem to be good enough.
Nigel
Devon
Gitup F1, A129, B1W, B2W
View attachment 53116Do you use anything in particular?
Are you sure that the haze in your image is not from water droplets in the air between the car and the lamp?
The weather has been a bit damp recently...
Paul Iddon
Paul Iddon
Preston
It's still there after wipers and demisters have been used. I have a heated front windscreen.
Can't wipe the glass on the inside before every journey to remove owt.
But my old tub isn't good for moisture....
Nigel
Devon
Does look to me like it is outside, and just caused by the damp weather.
Are you saying that if you do wipe the glass on the inside before a journey then it disappears?
If it is moisture in the air then it may disappear due to the weather rather than cleaning so it can be hard to tell without several checks!
Also, note that it will be more visible the darker it is outside, so again care is needed in the testing.
Paul Iddon
Paul Iddon
Preston
I didn't wipe inside but after a 15 minute drive it's no different having used blowers or the heated element.
Nigel
Devon
Some of it could be reflections off the heater elements, have you ever had a nice clean image in that car in proper darkness?
